Sorry mr. ronjonp for wasting your time.
Aggression cannot, under any circumstances, solve none problem!
You did not waste my time... :unsure:
  • Replies 28
  • lido
    9
  • rlx
    6
  • ronjonp
    5
  • hanhphuc
    4
Just test only..
[color="green"];At this level we can list out [/color]
([color="blue"]vl-registry-descendents[/color]  (strcat "HKEY_LOCAL_MACHINE\\"
	 (vlax-product-key)
	 "\\Applications\\")
[color="green"];but why this level doesn't work ???[/color]
  (vlax-product-key)
  "\\Applications\\"
  "AcEAttEdit"
  [color="red"]"\\Commands"[/color]
another approach
(defun foo (app cmd)
 (and (setq app (findfile app))
      (vl-registry-read
	 (vlax-product-key)
	 "\\Applications\\"
	 (vl-filename-base app)
	 "\\Commands")
	 (strcase cmd )
_$ (foo "AcEAttEdit.arx" "EATTEDIT")
[b][color="blue"]T[/color][/b]
Thank you hanhphuc for your replay.
Your first snippet returns a list containing the loaded applications. Not at all built-in commands. So, your second snippet return nil for any (?) built-in command.
yes that's the problem, if we could get the commands descendent list then we could collect all the command, but it failed.
That's why I tried another predicate sub (foo app ac cmd) ;edited post#20
but this method is not user friendly unless you know the app & name or (app list by vlookup or assoc)
app="AcTable.arx" name="AcadTable"
example:
(foo "AcTable.arx" "AcadTable" "TINSERT")
IMO Roy043 has offered the best solution :thumbsup:
Edited by hanhphuc
the best deserves the smiley
To my knowledge there is no way to obtain a list of command names via Lisp code.
For _eattedit and other commands that require user input something like this should work (on most CAD platforms I believe):
(defun CommandAvailable_P (cmd / ret)
Smart one Roy! :geek:
Agreed :) .. nice job.
i think i missed something , i fixed here
(defun appcom ( / key l lst )
;hanhphuc 13.04.2018
 (setq key (strcat "HKEY_LOCAL_MACHINE\\" (vlax-product-key) "\\Applications\\"))
 (cdr (acad_strlsort
 (apply 'append
	(mapcar ''((app)
		   (vl-registry-descendents
		    (strcat key app "\\Commands")
		    [color="red"]app[/color]
		  key
384 arx commands @ ac2007
("-3DCONFIG"
 "-AecDwgUnits"     "-AecExportToAutoCAD"		   "-ARCHIVE"	      "-BEDIT"		 "-BVHIDE"
 "-BVSHOW"	     "-BVSTATE"		"-COPYTOLAYER"	   "-DIMSTYLE"	      "-DWFADJUST"	 "-DWFATTACH"
 "-EATTEXT"	     "-ETRANSMIT"	"-FIELD"	   "-HYPERLINK"	      "-IMAGE"		 "-IMAGEADJUST"
 "-INTERFERE"	     "-LAYDEL"		"-LAYMCH"	   "-LAYMRG"	      "-MTEXT"		 "-OPENSHEETSET"
 "-PLOTSTAMP"	     "-PUBLISH"		"-REFEDIT"	   "-SHADEMODE"	      "-TABLE"		 "-UNITS"
 "-UPDATEFIELD"     "-VBALOAD"		"-VBARUN"	   "+DSETTINGS"	      "+PUBLISH"	 "3DALIGN"
 "3DCLIP"	     "3DCONFIG"		"3DCORBIT"	   "3DDISTANCE"	      "3DDWF"		 "3DDWFPUBLISH"
 "3DFLY"	     "3DFORBIT"		"3DORBIT"	   "3DORBITCTR"	      "3DORBITTRANSPARENT"
 "3DPAN"	     "3DPANTRANSPARENT"	"3DSIN"		   "3DSWIVEL"	      "3DSWIVELTRANSPARENT"
 "3DWALK"	     "3DZOOM"		"3DZOOMTRANSPARENT"		      "ACAD_INTERNAL_CELLSELECT"
 "ACAD_INTERNAL_REPEATCELLEDIT"	"ACADBLOCKDIALOG"  "ACADWBLOCKDIALOG" "adc"		 "adcclose"
 "adccustomnavigate"			"adcenter"	   "adcnavigate"      "AecDisplayManagerConfigsSelection"
 "AecFileOpenMessage"			"AecFileSaveMessage"		      "AecObjectCopyMessage"
 "AecObjRelDump"    "AecObjRelShow"	"AecObjRelUpdate"  "AecPostDxfinFix"  "AecSetXrefConfig" "AecVersion"
 "AIDIMFLIPARROW"   "AIDIMPREC"	"AIDIMSTYLE"	   "AIDIMTEXTMOVE"    "ALIGN"		 "ANIPATH"
 "APPLOAD"	     "ARCHIVE"		"ARCTEXT"	   "ARRAY"	      "ASSIST"		 "ASSISTCLOSE"
 "ATEXT"	     "ATTACHURL"	"ATTEDIT"	   "ATTSYNC"	      "BACTION"		 "BACTIONSET"
 "BACTIONTOOL"	     "BASSOCIATE"	"BATTMAN"	   "BATTORDER"	      "BAUTHORPALETTE"	 "BAUTHORPALETTECLOSE"
 "BCLOSE"	     "BCYCLEORDER"	"BEDIT"		   "BGPLOTRECEIVE"    "BGRIPSET"	 "BLOCKICON"
 "BlookupTable"     "BMAKE"		"BMOD"		   "BPARAMETER"	      "BROWSER"		 "BROWSER2"
 "BSAVE"	     "BSAVEAS"		"BVHIDE"	   "BVSHOW"	      "BVSTATE"		 "cal"
 "CAMERA"	     "CHECKSTANDARDS"	"CHSPACE"	   "CLASSICIMAGE"     "content"		 "CONVERTCTB"
 "CONVERTOLDLIGHTS" "CONVERTOLDMATERIALS"		   "CONVERTPSTYLES"   "COPYTOLAYER"	 "cui"
 "cuiexport"	     "cuiimport"	"DASHBOARD"	   "DASHBOARDCLOSE"   "DBCCONFIGURE"	 "DBCCONNECT"
 "DBCDEFINELLT"     "DBCDEFINELT"	"DBCDELETELABELS"  "DBCDELETELINKS"   "DBCDELETELLT"	 "DBCDELETELT"
 "DBCDELETEQRY"     "DBCDISCONNECT"	"DBCEDITLINKEDTABLE"		      "DBCEDITLLT"	 "DBCEDITLT"
 "DBCEDITQRY"	     "DBCEDITTABLE"	"DBCEXECUTEQRY"	   "DBCEXPORTLINKS"   "DBCEXPORTQS"	 "DBCEXPORTTS"
 "DBCHIDELABELS"    "DBCIMPORTQRY"	"DBCIMPORTQS"	   "DBCIMPORTTS"      "DBCLINKCONVERSION"
 "DBCLINKMANAGER"   "DBCNEWQRYLT"	"DBCNEWQRYTABLE"   "DBCONNECT"	      "DBCPROPSLBLT"	 "DBCPROPSLT"
 "DBCRELOADLABELS"  "DBCSELECTLINKS"	"DBCSHOWLABELS"	   "DBCSYNC"	      "DBCVIEWLINKEDTABLE"
 "DBCVIEWTABLE"     "DDATTE"		"DDIM"		   "DDINSERT"	      "DDPLOTSTAMP"	 "DDPTYPE"
 "DDUNITS"	     "DDVPOINT"		"DETACHURL"	   "DIM"	      "DIM1"		 "DIMALIGNED"
 "DIMANGULAR"	     "DIMARC"		"DIMBASELINE"	   "DIMCENTER"	      "DIMCONTINUE"	 "DIMDIAMETER"
 "DIMDISASSOCIATE"  "DIMEDIT"		"DIMEX"		   "DIMHORIZONTAL"    "DIMIM"		 "DIMJOGGED"
 "DIMLINEAR"	     "DIMORDINATE"	"DIMOVERRIDE"	   "DIMRADIUS"	      "DIMREASSOCIATE"	 "DIMREGEN"
 "DIMROTATED"	     "DIMSTYLE"		"DIMTEDIT"	   "DIMVERTICAL"      "DISTANTLIGHT"	 "DRAWINGRECOVERY"
 "DRAWINGRECOVERYHIDE"			"DRAWORDER"	   "DSETTINGS"	      "DWFADJUST"	 "DWFATTACH"
 "DWFCLIP"	     "DWGPROPS"		"EATTEDIT"	   "EATTEXT"	      "EATTEXTEDIT"	 "EATTEXTUPDATE"
 "EPLOTEXT"	     "ETRANSMIT"	"ExacReload"	   "ExternalReferences"
 "ExternalReferencesClose"		"FIELD"		   "FILTER"	      "FIND"		 "FLATSHOT"
 "GEOGRAPHICLOCATION"			"HELIX"		   "HIDE"	      "HYPERLINK"	 "HYPERLINKBACK"
 "HYPERLINKFWD"     "HYPERLINKOPEN"	"HYPERLINKOPTIONS" "HYPERLINKSTOP"    "IMAGE"		 "IMAGEADJUST"
 "IMAGEATTACH"	     "IMAGECLIP"	"IMAGEFRAME"	   "IMAGEQUALITY"     "INTERFERE"	 "INTERNALTABLEDIT"
 "JOGSECTION"	     "JUSTIFYTEXT"	"LAYCUR"	   "LAYDEL"	      "LAYER"		 "LAYERP"
 "LAYERPMODE"	     "LAYFRZ"		"LAYISO"	   "LAYLCK"	      "LAYMCH"		 "LAYMRG"
 "LAYOFF"	     "LAYON"		"LAYTHW"	   "LAYTRANS"	      "LAYULK"		 "LAYUNISO"
 "LAYVPI"	     "LAYWALK"		"LEADER"	   "LIGHT"	      "LIGHTLIST"	 "LIGHTLISTCLOSE"
 "LIVESECTION"	     "MARKUP"		"MARKUPCLOSE"	   "MATCHCELL"	      "MATCHPROP"	 "MATERIALASSIGN"
 "MATERIALATTACH"   "MATERIALMAP"	"MATERIALS"	   "MATERIALSCLOSE"   "MIRROR3D"	 "MLEDIT"
 "MLSTYLE"	     "MOCORO"		"MOVEBAK"	   "MTEDIT"	      "MTEXT"		 "MTPROP"
 "NETLOAD"	     "NEWSHEETSET"	"NEWVIEW"	   "OLECONVERT"	      "OLEOPEN"		 "OLERESET"
 "OLESCALE"	     "OPENDWFMARKUP"	"OPENSHEETSET"	   "PAINTER"	      "PAINTPROP"	 "PASTEASHYPERLINK"
 "PLOTSTAMP"	     "POINTLIGHT"	"PPGETACADINPUT"   "PROPERTIES"	      "PROPERTIESCLOSE"	 "PROPULATE"
 "PUBLISH"	     "PUBLISHTOWEB"	"PURGE"		   "qcclose"	      "QDIM"		 "QLATTACH"
 "QLATTACHSET"	     "QLDETACHSET"	"QLEADER"	   "QSELECT"	      "quickcalc"	 "RECTANG"
 "RECTANGLE"	     "REFCLOSE"		"REFEDIT"	   "REFSAVE"	      "REFSET"		 "RENDER"
 "RENDERCROP"	     "RENDERENVIRONMENT"		   "RENDERPRESETS"    "RENDERWIN"	 "RESETBLOCK"
 "REVCLOUD"	     "ROTATE3D"		"RPREF"		   "RPREFCLOSE"	      "RTEXT"		 "SAVEIMG"
 "ScaleListEdit"    "SCALETEXT"	"SECTIONPLANE"	   "SECURITYOPTIONS"  "SELECTURL"	 "Setidrophandler"
 "SHADE"	     "SHADEMODE"	"SHEETSET"	   "SHEETSETHIDE"     "SIGVALIDATE"	 "SOLDRAW"
 "SOLPROF"	     "SOLVIEW"		"SPACETRANS"	   "SPOTLIGHT"	      "STANDARDS"	 "SUNPROPERTIES"
 "SUNPROPERTIESCLOSE"			"SYSVDLG"	   "TABLE"	      "TABLEDIT"	 "TABLEEXPORT"
 "TABLESTYLE"	     "TaskBar"		"TEXTTOFRONT"	   "TINSERT"	      "TOLERANCE"	 "TOOLPALETTES"
 "TOOLPALETTESCLOSE"			"TRANSPARENCY"	   "TXT2MTXT"	      "UNITS"		 "UPDATEFIELD"
 "UPDATETHUMBSNOW"  "VBAIDE"		"VBALOAD"	   "VBAMAN"	      "VBANEW"		 "VBAPREF"
 "VBARUN"	     "VBASTMT"		"VBAUNLOAD"	   "VIEW"	      "VIEWPLOTDETAILS"	 "VISUALSTYLES"
 "VISUALSTYLESCLOSE"			"VPMAX"		   "VPMIN"	      "VTOPTIONS"	 "WALKFLYSETTINGS"
 "WHOHAS"	     "WIPEOUT"		"XOPEN"		   "XP"		      "XPLODE"
you can use vl-position , member etc..
(defun bar (cmd) (vl-some ''((x) (wcmatch ([color="blue"]strcase[/color] x) (strcat (strcase cmd)"*"))) (appcom)))
_$ (bar  "eattedit")
T
Edited by hanhphuc
strcase
Noticed that vlax-product-key can contain an addition code so by removing it you get the result you want.
; hanhphuc 13.04.2018
(defun appcom ( / key pk i l lst )
 (if (setq i (vl-string-position (ascii ":") (setq pk (vlax-product-key)))) (setq pk (substr pk 1 i)))
 (setq key (strcat "HKEY_LOCAL_MACHINE\\" pk "\\Applications\\"))
 (cdr (acad_strlsort (apply 'append (mapcar ''((app) (vl-registry-descendents (strcat key app "\\Commands") app))(vl-registry-descendents key))))))
this probably also would do the trick :
(vl-registry-descendents (strcat "HKEY_LOCAL_MACHINE\\" (if (setq i (vl-string-position (ascii ":") (setq pk (vlax-product-key)))) (substr pk 1 i) pk) "\\Applications\\"))
Edited by rlx
@grrr thanks but it was VL trick respond "OP's topic - list the commands" not worth flettery :oops: but what MP's listing code was really impressed!!
After all Roy's solution is more relevant as it met "KISS" principle :thumbsup:
@rlx IMO registry path product-key maybe varies due to different version ,thanks anyway :)
(defun appcom ( / key [b][color="red"]l lst[/color][/b] )  [color="green"];<-- the [color="red"]l lst[/color] variables unused can be removed.[/color]
The reason was initially using [color="blue"]foreach[/color] later changed to [color="blue"]mapcar[/color]...
