Change color (RGB) of objects in a selection set
Ament
Hello together,
I thought I have a simple task to perform, but unfortunately it turned out to be more difficult than I expected:
I have in my lisp a code to select all elements in a drawing using (setq tbe (ssget "_X")), what I want to do now is to change the color of the selectionset to have a certain color. This color is defined by the RGB code 102,204,255.
Unfortunately I was not able to find the important hint to solve it by my own :(
Thank you for your help,
Ament
Try this:
(defun c:foo (/ s)
 (if (setq s (ssget ":L"))
   (foreach e (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))
     (entmod (append (entget e) '((420 . 6737151))))
Hi nahhphuc, unfortunately I'm a beginner in LISP and not able to identify the relevant code in the threat you mentioned :( Could you give me the hint?
To convert the rgb use lee-mac function
;; RGB -> True  -  Lee Mac
;; Args: r,g,b - [int] Red, Green, Blue values
(defun LM:RGB->True ( r g b )
   (logior (lsh (fix r) 16) (lsh (fix g)  (fix b))
;(setq rgb (LM:RGB->True R G B))
(setq rgb (LM:RGB->True 102 204 255))
;6737151
  • 2 months later...
Wonderfull. It works just perfectly for me. Thanks again!
autocad chprop command would change the selected item color. is I am missing something ?
yeah , you're missing all the fun of trying to use no command calls :D
:) haha big time learner here. i know only some functions of autolisp activex functions are like god for me i know its there but don't know how to use hahahaha (need your tips for better learning). thank you
No, thats called Masochism. :lol:
my wife doesn't like commands too haha
