Hello Everyone.
I have a Lisp to rename the Layer by Part of Layer name. but the code is not working.
(defun C:Test()
(if (setq xlay (ssget "_X" '((8 . "*_Proposed_*"))))
(command "-layer" "r" xlay "Proposed Entity" "")
I want to select the layers which is having "Proposed" in their Name, then rename to PROPOSED ENTITY.
(Layer names like, Region_Proposed_Street, City_Proposed_street)
If someone can help me thank you very much.
Hello Everyone.
(defun C:Test()
Your code isn't working and won't work because: 1. You are trying to pass a selection set to the layer command. 2. The selection set will contain all entities on layers with "Proposed" in the layer name, NOT the layer itself. 3. Your code is attempting to give multiple layers the same name, unless your mean to substitute "Proposed Entity" for "Proposed" in the existing layer name? 1 & 2 are surmountable , but 3 isn't and needs a rethink e.g.
Is there any other way to do this..?
Whatever the layers having Proposed in their name. That should be rename to Proposed Entity.
Can we done by using Layer merge.?
Hi,
Just create that new layer name if its already existed then make a selection set of those objects on the old layers then move them to the new layer.
As per Tharwat's post this should accomplish what you want :
(defun c:move2layer ( / *error* c_doc c_lyrs cmde n_lyr ss ss_objs)
  (defun *error* ( msg )
     (if cmde (setvar 'cmdecho cmde))
     (if (and c_doc (= 8 (logand 8 (getvar 'UNDOCTL)))) (vla-endundomark c_doc))
     (if (not (wcmatch (strcase msg) "*BREAK*,*CANCEL*,*EXIT*")) (princ (strcat "\nAn Error : " msg " occurred.")))
  );_end_*error*_defun
  (setq c_doc (vla-get-activedocument (vlax-get-acad-object))
        c_lyrs (vla-get-layers c_doc)
        n_lyr "Proposed Entity"
  (if (/= (getvar 'cmdecho) 0) (progn (setq cmde (getvar 'cmdecho)) (setvar 'cmdecho 0)))
  (vla-startundomark c_doc)
  (if (not (tblsearch "layer" "Proposed Entity")) (vla-add c_lyrs n_lyr))
  (setq ss (ssget "_X" '((8 . "*_Proposed_*"))))
  (if ss (setq ss_objs (vla-get-activeselectionset c_doc)))
  (vlax-for obj ss_objs
     (vlax-put obj 'Layer n_lyr)
  (setq ss nil
        ss_objs nil
);end_defun
Type "move2layer" to run
It will move all objects on layers with "_Proposed_" in their name into a layer called "Proposed Entity".
If the layer doesn't exist it will create it.
Hi Tharwat
Thanks for your reply..
Could you please tell me how to do this.?
Hi Tharwat
Hi,
Be sure to have objects on unlocked layers in prior of invoking / running the following routine.
(defun c:Test ( / s i o e)
    (and (setq i -1 s (ssget "_X" '((8 . "*_Proposed_*"))))
         (while (setq o (ssname s (setq i (1+ i))))
            (entmod (subst '(8 . "Proposed Entity") (assoc 8 (setq e (entget o))) e)))
Thank you so much Tharwat..
It's worked perfectly.
:D
