i have been using LeeMacs routine to "Buffer" the polylines.
thanks to the guy, but still its time consuming specially when working on big scale workspace...
;; Advanced LWPolyline Outline  -  Lee Mac
;; Example calling functions (these may be customised to suit your requirements):
;; Single selection
(defun c:polyout ( / *error* cmd enl ent lst ped )
   (defun *error* ( msg )
       (if (= 'int (type cmd))
           (setvar 'cmdecho cmd)
       (if (= 'int (type ped))
           (setvar 'peditaccept ped)
       (LM:endundo (LM:acdoc))
       (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
   (if
       (setq ent
           (LM:ssget "\nSelect LWPolyline: "
                   "_+.:E:S:L"
                       (0 . "LWPOLYLINE")
                       (-4 . "<OR")
                           (-4 . "<>") (40 . 0.0)
                           (-4 . "<>") (41 . 0.0)
                       (-4 . "OR>")
           (LM:startundo (LM:acdoc))
           (setq cmd (getvar 'cmdecho)
                 ped (getvar 'peditaccept)
                 enl (entlast)
           (setvar 'cmdecho 0)
           (setvar 'peditaccept 1)
           (LM:AdvPolyOutline (setq ent (ssname ent 0)))
           (if (not (equal enl (entlast)))
                   (while (setq enl (entnext enl))
                       (if (wcmatch (cdr (assoc 0 (entget enl))) "LINE,ARC")
                           (setq lst (cons enl lst))
                   (if lst
                           (command "_.pedit" "_M")
                           (foreach x lst (command x))
                           (command "" "_J" "" "")
                   (initget "Yes No")
                   (if (/= "No" (getkword "\nDelete Original? [Yes/No] <Yes>: ")) (entdel ent))
               (princ "\nUnable to outline selected LWPolyline.")
;; Multiple selection
(defun c:mpolyout ( / *error* cmd del enl ent err inc lst ped sel )
   (if
       (setq sel
           (LM:ssget "\nSelect LWPolylines: "
                   "_:L"
                       (0 . "LWPOLYLINE")
                       (-4 . "<OR")
                       (-4 . "OR>")
           (initget "Yes No")
           (setq del (/= "No" (getkword "\nDelete Original? [Yes/No] <Yes>: ")))
                 err 0
           (setvar 'cmdecho 0)
           (repeat (setq inc (sslength sel))
               (setq enl (entlast)
                     lst nil
               (LM:AdvPolyOutline (setq ent (ssname sel (setq inc (1- inc)))))
                       (if lst
                       (if del (entdel ent))
                   (setq err (1+ err))
           (if (< 0 err)
               (princ (strcat "\nUnable to outline " (itoa err) " selected LWPolyline(s)."))
;;------------------=={ Advanced LWPolyline Outline }==-----------------;;
;;  Constructs the outline silhouette of an LWPolyline entity with      ;;
;;  straight and arc segments of varying width. The resulting           ;;
;;  silohuette is composed of Line, Circular Arc & Elliptical Arc       ;;
;;  entities.                                                           ;;
;;  The function is currently limited for use with                      ;;
;;  non-self-intersecting LWPolylines.                                  ;;
;;  The function will produce best results for arc segments whose       ;;
;;  vertex locations have not been independently modified following     ;;
;;  creation of the LWPolyline; i.e. arc segments which remain tangent  ;;
;;  to surrounding segments.                                            ;;
;;  The function will approximate LWPolyline arc segments that have a   ;;
;;  varying start & end width with an Elliptical Arc entity; however,   ;;
;;  arc segments spanning more than pi radians, or with a high width    ;;
;;  differential along the length of the segment will not necessarily   ;;
;;  define an outlining Elliptical Arc.                                 ;;
;;  Author:  Lee Mac, Copyright © 2013  -  www.lee-mac.com              ;;
;;  Arguments:                                                          ;;
;;  ent - Entity name of LWPolyline                                     ;;
;;  Returns:  -None-                                                    ;;
(defun LM:AdvPolyOutline ( ent / _endpoints cls enx ep1 ep2 lst ocs )
   (defun _endpoints ( en bu / ax bx cn mt p1 pl ra rd zv )
       (setq en (entget en)
             zv (cdr (assoc 210 en))
       (setq pl
           (cond
               (   (= "LINE" (cdr (assoc 0 en)))
                   (list
                       (cdr (assoc 10 en))
                       (cdr (assoc 11 en))
               (   (= "ARC" (cdr (assoc 00 en)))
                   (setq cn (cdr (assoc 10 en))
                         rd (cdr (assoc 40 en))
                   (mapcar '(lambda ( a ) (trans (polar cn (cdr (assoc a en)) rd) zv 0)) '(50 51))
               (   t
                   (setq cn (trans (cdr (assoc 10 en)) 0 zv)
                         p1 (trans (cdr (assoc 11 en)) 0 zv)
                         ax (distance '(0.0 0.0) p1)
                         bx (* ax (cdr (assoc 40 en)))
                         ra (angle '(0.0 0.0) p1)
                         mt (list (list (cos ra) (- (sin ra))) (list (sin ra) (cos ra)))
                   (mapcar '(lambda ( u ) (trans (mapcar '+ cn (mxv mt (list (* ax (cos u)) (* bx (sin u))))) zv 0))
                       (list
                           (cdr (assoc 41 en))
                           (cdr (assoc 42 en))
       (if (minusp bu) (reverse pl) pl)
   (setq enx (entget ent)
         ocs (cdr (assoc 210 enx))
         cls (= 1 (logand 1 (cdr (assoc 70 enx))))
         lst (LM:LWVertices enx)
   (foreach grp
       (setq lst
           (apply 'mapcar
               (cons 'list
                   (mapcar
                       (function
                           (lambda ( a b / bu ew p1 p2 sw )
                               (setq p1 (cdr (assoc 10 a))
                                     p2 (cdr (assoc 10 b))
                                     sw (/ (cdr (assoc 40 a)) 2.0)
                                     ew (/ (cdr (assoc 41 a)) 2.0)
                                     bu (cdr (assoc 42 a))
                               (mapcar
                                   (function
                                       (lambda ( fn / a1 cn el i1 i2 nm pl rd v1 w1 )
                                           (cons
                                               (cond
                                                   (   (equal 0.0 bu 1e-
                                                       (setq v1 (mapcar '- p1 p2)
                                                             v1 (list (- (cadr v1)) (car v1))
                                                             nm (distance '(0.0 0.0) v1)
                                                       (if (equal 0.0 nm 1e-14)
                                                           (setq v1 '(0.0 0.0))
                                                           (setq v1  (mapcar '/ v1 (list nm nm)))
                                                       (entmakex
                                                           (list
                                                              '(0 . "LINE")
                                                               (cons 10 (trans (mapcar 'fn p1 (vxs v1 sw)) ocs 0))
                                                               (cons 11 (trans (mapcar 'fn p2 (vxs v1 ew)) ocs 0))
                                                   (   (equal sw ew 1e-
                                                       (setq rd (LM:BulgeRadius p1 p2 bu)
                                                             cn (LM:BulgeCentre p1 p2 bu)
                                                       (entmakex
                                                           (list
                                                              '(0 . "ARC")
                                                               (cons 010 cn)
                                                               (cons 040 (fn rd (if (minusp bu) (- sw) sw)))
                                                               (cons 050 (if (minusp bu) (angle cn p2) (angle cn p1)))
                                                               (cons 051 (if (minusp bu) (angle cn p1) (angle cn p2)))
                                                               (cons 210 ocs)
                                                   (   t
                                                             i1 (atan bu)
                                                             i2 (/ (- ew sw) (if (minusp bu) -4.0 4.0))
                                                             a1 (angle cn p1)
                                                             w1 (fn rd (if (minusp bu) (- sw) sw))
                                                       (repeat 5
                                                           (setq pl (cons (polar cn a1 w1) pl)
        a1 (+  a1 i1)
        w1 (fn w1 i2)
                                                       (if (apply 'LM:Clockwise-p (cddr pl))
                                                           (setq pl (reverse pl))
                                                       (if (setq el (apply 'LM:5P-Ellipse pl))
                                                           (entmakex
                                                               (append
        (000 . "ELLIPSE")
        (100 . "AcDbEntity")
        (100 . "AcDbEllipse")
        el
        (list
        (cons 041 (LM:point->param el (car  pl)))
        (cons 042 (LM:point->param el (last pl)))
        (cons 210 ocs)
                                               (list p1 p2 sw ew bu)
                                   (list + -)
                       lst
                       (if cls
                           (append (cdr lst) (list (car lst)))
                           (cdr lst)
       (mapcar
           (function
               (lambda ( a b / e1 e2 ip p1 p2 q1 q2 )
                   (cond
                       (   (or (null (car a)) (null (car b))))
                       (   (and
                               (equal 0.0 (last a) 1e-
                               (equal 0.0 (last b) 1e-
                           (setq e1 (entget (car a))
                                 e2 (entget (car b))
                                 p1 (cdr (assoc 10 e1))
                                 p2 (cdr (assoc 11 e1))
                                 q1 (cdr (assoc 10 e2))
                                 q2 (cdr (assoc 11 e2))
                           (cond
                               (   (equal
                                       (vx1 (mapcar '- (caddr a) (cadr a)))
                                       (vx1 (mapcar '- (caddr b) (cadr b)))
                                       1e-3
                                   (if (not (equal p2 q1 1e-)
                                       (entmake (list '(0 . "LINE") (cons 10 p2) (cons 11 q1)))
                               (   (setq ip
                                       (inters
                                           (trans p1 0 1)
                                           (trans p2 0 1)
                                           (trans q1 0 1)
                                           (trans q2 0 1)
                                           nil
                                   (setq ip (trans ip 1 0))
                                   (entmod (subst (cons 11 ip) (assoc 11 e1) e1))
                                   (entmod (subst (cons 10 ip) (assoc 10 e2) e2))
                       (   (not (equal (car (cddddr a)) (cadddr b) 1e-)
                           (entmake
                               (list
                                  '(0 . "LINE")
                                   (cons 10 (cadr (_endpoints (car a) (last a))))
                                   (cons 11 (car  (_endpoints (car b) (last b))))
           grp
           (if cls
               (append (cdr grp) (list (car grp)))
               (cdr grp)
   (if (not cls)
       (foreach f (list car cadr)
           (if
               (and (caaar lst) (caaadr lst)
                   (not
                       (equal
                           (setq ep1 (f (_endpoints (caaar  lst) (last (caar  lst)))))
                           (setq ep2 (f (_endpoints (caaadr lst) (last (caadr lst)))))
                           1e-8
               (entmake (list '(0 . "LINE") (cons 10 ep1) (cons 11 ep2)))
           (setq lst (mapcar 'reverse lst))
;; 5-Point Ellipse  -  Lee Mac
;; Args: p1,p2,p3,p4,p5 - UCS points defining Ellipse
;; Returns a list of: ((10 <WCS Center>) (11 <WCS Major Axis Endpoint from Center>) (40 . <Minor/Major Ratio>))
(defun LM:5P-Ellipse ( p1 p2 p3 p4 p5 / a av b c cf cx cy d e f i m1 m2 rl v x )
   (setq m1
       (trp
           (mapcar
               (function
                   (lambda ( p )
                       (list
                           (* (car  p) (car  p))
                           (* (car  p) (cadr p))
                           (* (cadr p) (cadr p))
                           (car  p)
                           (cadr p)
                           1.0
               (list p1 p2 p3 p4 p5)
   (setq i -1.0)
   (repeat 6
       (setq cf (cons (* (setq i (- i)) (detm (trp (append (reverse m2) (cdr m1))))) cf)
             m2 (cons (car m1) m2)
             m1 (cdr m1)
   (mapcar 'set '(f e d c b a) cf) ;; Coefficients of Conic equation ax^2 + bxy + cy^2 + dx + ey + f = 0
   (if (< 0 (setq x (- (* 4.0 a c) (* b b))))
           (if (equal 0.0 b 1e- ;; Ellipse parallel to coordinate axes
               (setq av '((1.0 0.0) (0.0 1.0))) ;; Axis vectors
               (setq av
                   (mapcar
                       (function
                           (lambda ( v / d )
                               (setq v (list (/ b 2.0) (- v a)) ;; Eigenvectors
                                     d (distance '(0.0 0.0) v)
                               (mapcar '/ v (list d d))
                       (quad 1.0 (- (+ a c)) (- (* a c) (* 0.25 b b))) ;; Eigenvalues
           (setq cx (/ (- (* b e) (* 2.0 c d)) x) ;; Ellipse Center
                 cy (/ (- (* b d) (* 2.0 a e)) x)
           ;; For radii, solve intersection of axis vectors with Conic Equation:
           ;; ax^2 + bxy + cy^2 + dx + ey + f = 0  }
           ;; x = cx + vx(t)                       }- solve for t
           ;; y = cy + vy(t)                       }
           (setq rl
               (mapcar
                   (function
                       (lambda ( v / vv vx vy )
                           (setq vv (mapcar '* v v)
                                 vx (car  v)
                                 vy (cadr v)
                           (apply 'max
                               (quad
                                   (+ (* a (car vv)) (* b vx vy) (* c (cadr vv)))
                                   (+ (* 2.0 a cx vx) (* b (+ (* cx vy) (* cy vx))) (* c 2.0 cy vy) (* d vx) (* e vy))
                                   (+ (* a cx cx) (* b cx cy) (* c cy cy) (* d cx) (* e cy) f)
                   av
           (if (apply '> rl)
               (setq rl (reverse rl)
                     av (reverse av)
           (list
               (cons 10 (trans (list cx cy) 1 0)) ;; WCS Ellipse Center
               (cons 11 (trans (mapcar '(lambda ( v ) (* v (cadr rl))) (cadr av)) 1 0)) ;; WCS Major Axis Endpoint from Center
               (cons 40 (apply '/ rl)) ;; minor/major ratio
;; Matrix Determinant (Upper Triangular Form)  -  ElpanovEvgeniy
;; Args: m - nxn matrix
(defun detm ( m / d )
   (cond
       (   (null m) 1)
       (   (and (zerop (caar m))
                (setq d (car (vl-member-if-not (function (lambda ( a ) (zerop (car a)))) (cdr m))))
           (detm (cons (mapcar '+ (car m) d) (cdr m)))
       (   (zerop (caar m)) 0)
       (   (*  (caar m)
               (detm
                   (mapcar
                       (function
                           (lambda ( a / d ) (setq d (/ (car a) (float (caar m))))
                               (mapcar
                                   (function
                                       (lambda ( b c ) (- b (* c d)))
                                   (cdr a) (cdar m)
                       (cdr m)
;; Matrix Transpose  -  Doug Wilson
(defun trp ( m )
   (apply 'mapcar (cons 'list m))
;; Quadratic Solution  -  Lee Mac
;; Args: a,b,c - coefficients of ax^2 + bx + c = 0
(defun quad ( a b c / d r )
   (if (<= 0 (setq d (- (* b b) (* 4.0 a c))))
           (setq r (sqrt d))
           (list (/ (+ (- b) r) (* 2.0 a)) (/ (- (- b) r) (* 2.0 a)))
;; Unit Vector  -  Lee Mac
;; Args: v - vector in R^2 or R^3
(defun vx1 ( v )
   (   (lambda ( n ) (if (equal 0.0 n 1e-10) nil (mapcar '/ v (list n n n))))
       (distance '(0.0 0.0 0.0) v)
;; Vector x Scalar  -  Lee Mac
;; Args: v - vector in R^n, s - real scalar
(defun vxs ( v s )
   (mapcar (function (lambda ( n ) (* n s))) v)
;; Matrix x Vector  -  Vladimir Nesterovsky
;; Args: m - nxn matrix, v - vector in R^n
(defun mxv ( m v )
   (mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
;; ArcCosine  -  Lee Mac
;; Args: -1 <= x <= 1
(defun acos ( x )
   (if (<= -1.0 x 1.0)
       (atan (sqrt (- 1.0 (* x x))) x)
;; Clockwise-p - Lee Mac
;; Returns T if p1,p2,p3 are clockwise oriented
(defun LM:Clockwise-p ( p1 p2 p3 )
   (<  (* (- (car  p2) (car  p1)) (- (cadr p3) (cadr p1)))
       (* (- (cadr p2) (cadr p1)) (- (car  p3) (car  p1)))
;; Point -> Ellipse Parameter  -  Lee Mac
;; Returns the elliptical arc parameter value for the given point
;; dxf  - [lst] Ellipse DXF data (DXF groups 10, 11 & 40)
;; pt   - [lst] Point on Ellipse
(defun LM:point->param ( dxf pt / a b m r u x y )
   (setq m (trans (cdr (assoc 11 dxf)) 0 1)
         a (distance '(0.0 0.0) m)
         b (* (cdr (assoc 40 dxf)) a)
         r (angle '(0.0 0.0) m)
   (mapcar 'set '(x y)
       (mxv (list (list (cos r) (sin r)) (list (- (sin r)) (cos r)))
            (mapcar '- pt (trans (cdr (assoc 10 dxf)) 0 1))
   (if (< y 0)
       (setq u (- (+ pi pi) (acos (/ x a))))
       (setq u (acos (/ x a)))
   (rem (+ pi pi u) (+ pi pi))
;; LW Vertices  -  Lee Mac
;; Returns a list of lists in which each sublist describes
;; the position, starting width, ending width and bulge of the
;; vertex of a supplied LWPolyline
(defun LM:LWVertices ( e )
   (if (setq e (member (assoc 10 e) e))
       (cons
           (list
               (assoc 10 e)
               (assoc 40 e)
               (assoc 41 e)
               (assoc 42 e)
           (LM:LWVertices (cdr e))
;; Bulge Radius  -  Lee Mac
;; p1 - [lst] start vertex
;; p2 - [lst] end vertex
;; b  - [rea] bulge
;; Returns: [rea] the radius of the arc described by the given bulge and vertices
(defun LM:BulgeRadius ( p1 p2 b )
   (/ (* (distance p1 p2) (1+ (* b b))) 4 (abs b))
;; Bulge Centre  -  Lee Mac
;; b  - [rea] bulge
;; Returns: [lst] the centre of the arc described by the given bulge and vertices
(defun LM:BulgeCentre ( p1 p2 b )
   (polar p1
       (+ (angle p1 p2) (- (/ pi 2) (* 2 (atan b))))
       (/ (* (distance p1 p2) (1+ (* b b))) 4 b)
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg params / sel )
   (princ msg)
   (setvar 'nomutt 1)
   (setq sel (vl-catch-all-apply 'ssget params))
   (setvar 'nomutt 0)
   (if (not (vl-catch-all-error-p sel)) sel)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
   (LM:endundo doc)
   (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
   (while (= 8 (logand 8 (getvar 'undoctl)))
       (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
   (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
   (LM:acdoc)
(vl-load-com)
(princ
   (strcat
       "\n:: AdvancedPolyOutline.lsp | Version 1.1 | \\U+00A9 Lee Mac "
       (menucmd "m=$(edtime,0,yyyy)")
       " www.lee-mac.com ::"
       "\n:: Available Commands: "
       "\n::     \"polyout\"  -  Single selection."
       "\n::    \"mpolyout\"  -  Multiple selection."
;;                             End of File                              ;;
I added a sample DWG to what i have been doing over and over, and i need help
sample.dwg
Two commands to merge them:
Region >> select your polylines
Union >> previous
Union >> previous
i use it.
thanks though... but the endings of the polylines ate straight. i want it to be curved so im a bit slow when i have so much polylines.
thats why im asking to tweak the code. or atleast have a code to make the ends curved like on sample DWG
