Help with a Lisp routine turn off layers containing "a phrase or number"
hello ,
i am a complete novice only know some basics
i work on drawings with 100's of layers and sometimes 100's of XREF's
i would like some help on writing a routine
i would like to run a routine called simplelayout
and this routine would turn off any layers containing AM_5 for example
please please please help me and dont hesitate to ask me questions
it is driving me nuts
The _-Layer command will accept wildcards in layer names.
(command "_.-layer" "_off" "*AM_5*" "")
Hi,
Or this if you are not a fan of command calls like me.
(defun c:Test (/ l n v e)
 (while (setq l (tblnext "LAYER" (not l)))
   (and (wcmatch (setq n (cdr (assoc 2 l))) "*AM_5*")
        (or (minusp (setq v (cdr (assoc 62 (setq e (entget (tblobjname "LAYER" n)))))))
            (entmod (append e (list (cons 62 (- v)))))
Thank you so much!!!!!!!
