KARDOLITO89 Posted May 13, 2018 Share Posted May 13, 2018 hello when executing the commands the elements are duplicated in the same place, will there be any way that does not happen? and that the command be repeated Thank you. ((defun c: cr () (princ "\ n Copiar, & Girar: \ n") (setq ss (ssget)) (comando "copiar" ss "" "0" "0") (comando "mover" ss "" pause pause) (comando "rotar" ss "" "@" pause)) (defun c: mr () (princ "\ nMover, & Rotate: \ n") (setq ss (ssget)) (comando "Move" ss "" "0" "0") (comando "move" ss "" pause pause) (comando "rotar" ss "" "@" pause)) Quote Link to comment Share on other sites More sharing options...
dlanorh Posted May 14, 2018 Share Posted May 14, 2018 hello when executing the commands the elements are duplicated in the same place, will there be any way that does not happen? and that the command be repeatedThank you. ((defun c: cr () (princ "\ n Copiar, & Girar: \ n") (setq ss (ssget)) (comando "copiar" ss "" "0" "0") (comando "mover" ss "" pause pause) (comando "rotar" ss "" "@" pause)) (defun c: mr () (princ "\ nMover, & Rotate: \ n") (setq ss (ssget)) (comando "Move" ss "" "0" "0") (comando "move" ss "" pause pause) (comando "rotar" ss "" "@" pause)) This line creates a copy in the same place (comando "copiar" ss "" "0" "0") This line does nothing (comando "Move" ss "" "0" "0") If you want to copy it should be (comando "copiar" ss "" pause) If you want to move it should be (comando "move" ss "" pause) Note only one pause is needed, and it will always work on the originally selected entities Quote Link to comment Share on other sites More sharing options...
hanhphuc Posted May 15, 2018 Share Posted May 15, 2018 command: MOCORO ? Quote Link to comment Share on other sites More sharing options...
