bogeymen77
looking for a lisp to offset and change the new line color in the same layer
bogeymen77
Hi,
i'm looking for a lisp that will offset a line to a distance of 1.875 and change the color from blue to white.
thanks.
Share this post
Link to post
BIGAL
Just write down the steps you do manually and its 90% done start with (command "offset" .... use Pause for the two pick's required.
2nd hint (command "chprop" "L".....
Share this post
Link to post
bogeymen77
Thank you.
but i'm not to sure to understand.. i'm new to lisp.
so if i normally do:
"o" (offset) 1.875 (enter) chose the line, chose where i want it.
than i click on the new line and manually change the color to white...
so for now i did add this line:
;counter top offset 1.875
(defun c:OC () (command "Offset" 1.875 pause)(princ))
and i use this command line to change the color after i did the offset..
(defun c:C1 ()
(command "CHANGE" (ssget) "" "P" "C" "WHITE" "")
but what i don't know is how to combine them. i want the new offset line to change color each time i do the offset.
thank
Share this post
Link to post
dlanorh
Thank you.
(defun c:C1 ()
thank
(defun c:OC ( / ent pt)
(setq ent (car (entsel "\nSelect Line to Offset : ")))
(initget 1)
(setq pt (getpoint "\n Select side to offset : "))
(command "Offset" 1.875 ent pt "")
(command "CHANGE" (entlast) "" "P" "C" "WHITE" "")
Edited by dlanorh
Share this post
Link to post
BIGAL
Good to see you have a go its how to learn, you were very close, dlanorh tidied it.
Share this post
Link to post
bogeymen77
Awesome !!
Thank you very much dlanorh that will save me a lot of time at the end of the day.
Thank you Bigal too.
Share this post
Link to post
dlanorh
Awesome !!
Not a problem, now you have to figure out how to make it better or do more. ;)
Share this post
Link to post
