trefan123
Add previous objects to group
trefan123
Good day,
What i know is dangerous.
I have a basic lisp that draws a couple of lines and arc's.
(command "LINE" IP P4 P5 P6 P16 P15 P14 "C")
(command "LINE" P1 P8 "")
(command "LINE" P11 P18 "")
(Command "arc" P5 P7 P8 "")
(Command "arc" P8 P9 P18 "")
(Command "arc" P18 P17 P15 "")
I would like to group these items for ease of manipulation.
All help is appreciated.
Thanks
Peter
Share this post
Link to post
Grrr
Hi,
something like:
(setq objlist (list (setq entity (entlast))))
(while (setq entity (entnext entity))
 (setq objlist (cons (vlax-ename->vla-object entity) objlist))
(vlax-invoke
 (vla-add (vla-get-groups (vla-get-activedocument (vlax-get-acad-object))) "*")
 'appenditems
 objlist
Share this post
Link to post
Lee Mac
Here's another way, which may be easier to understand for a beginner:
(setq ent (entlast))
(while (setq tmp (entnext ent)) (setq ent tmp))
(command
   "_.line" "_non" IP   "_non" P4  "_non" P5 "_non" P6 "_non" P16 "_non" P15 "_non" P14 "_c"
   "_.line" "_non" P1   "_non" P8  ""
   "_.line" "_non" P11  "_non" P18 ""
   "_.arc"  "_non" P5   "_non" P7  "_non" P8
   "_.arc"  "_non" P8   "_non" P9  "_non" P18
   "_.arc"  "_non" P18  "_non" P17 "_non" P15
   "_.-group" "_c" "*" ""
(while (setq ent (entnext ent)) (command ent))
(command "")
@Grrr beware of circumstances in which the last entity in the database is complex (e.g. Heavy/3D polyline / attributed block)
Share this post
Link to post
Grrr
Thanks Lee, I just understood what you did in the first two rows of your suggestion, and then I read your remark. :thumbsup:
Now I think that a subfunction that determines if an entity is parent (returns boolean), would pair nicely with entnext.
Share this post
Link to post
trefan123
Thanks a lot. I seem to grasp what lee added, i did try the entlast previously ..just errors...
One question why put the non in front of the points?
Share this post
Link to post
trefan123
Here is the complete lisp, must have had the old one loaded as it worked but the addition fails
(defun C:boltside (/ IP P1 P2 P3 SIZE)
;================make and choose color=========================
(command "LAYER" "M" "Steel" "c" "green" "" "")
(command "color" "white" "")
(setvar 'osmode 53)
;=================insertion point========================
(setvar "CMDECHO" 0)
(setvar "BLIPMODE" 0)
(setq IP (getpoint "\nInsertion Point: "))
(setvar "OSMODE" 0)
(setq SIZE (getreal "\nEnter the Nominal Bolt Size--Metric-: ")
;====================get all points===================
(setq P1 (polar IP (DTR 180.0) (* 0.4330 SIZE))
P2 (polar IP (DTR 180.0) (* 0.6495 SIZE))
P3 (polar IP (DTR 180.0) (* 0.7655 SIZE))
P4 (polar IP (DTR 180.0) (* 0.8660 SIZE))
P9 (polar IP (DTR 90.0) (* 0.8000 SIZE))
P8 (polar P1 (DTR 90.0) (* 0.7420 SIZE))
P7 (polar P2 (DTR 90.0) (* 0.8000 SIZE))
P6 (polar P3 (DTR 90.0) (* 0.8000 SIZE))
P5 (polar P4 (DTR 90.0) (* 0.7420 SIZE))
P11 (polar IP (DTR 0.0) (* 0.4330 SIZE))
P12 (polar IP (DTR 0.0) (* 0.6495 SIZE))
P13 (polar IP (DTR 0.0) (* 0.7655 SIZE))
P14 (polar IP (DTR 0.0) (* 0.8660 SIZE))
P18 (polar P11 (DTR 90.0) (* 0.7420 SIZE))
P17 (polar P12 (DTR 90.0) (* 0.8000 SIZE))
P16 (polar P13 (DTR 90.0) (* 0.8000 SIZE))
P15 (polar P14 (DTR 90.0) (* 0.7420 SIZE))
;==================draw nut=======================
(command
(command "")
;================rotate to desired position=========================
(prompt "\nRotation Angle: ")
(command "ROTATE" "LAST" "" IP pause)
;================end=========================
(setvar 'osmode 53)
Share this post
Link to post
BIGAL
Just a suggestion
(setq a90 (/ pi 2.0)) ; this is 90 degrees
pi is 180 degrees use as is
(setq a180 pi)
(setq a270 (* pi 1.5)) this is 270 degrees
P3 (polar IP pi (* 0.7655 SIZE))
P18 (polar P11 a90 (* 0.7420 SIZE))
Share this post
Link to post
trefan123
this was not copied
(defun DTR (a) ;degrees to radians function
(* PI (/ a 180.0))
Share this post
Link to post
Lee Mac
This command modifier is short for "none" and instructs AutoCAD to ignore all active Object Snap modes for the next point input.
Share this post
Link to post
trefan123
learn something every day..
thanks again
Share this post
Link to post
Grrr
ha! I live with that motto..
Share this post
Link to post
BIGAL
trefan what I was getting at is the 90 180 270 are known values so you could predefine them in a startup lisp so no need for the dtr routine. Check out help on "Pi".
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
