Hi, help me, please.
I need lisp routine for insertion slope of the line in field (text, mtext, attribute, mleader or dim).
Steps:
1. Select object "Line".
2. Get Object Id.
3. Create field with formula: abs((delta y)/(delta x)) with conversion factor [0.2].
4. Set text height (by default 250).
5. Put text object in drawing or ask for object (text, mtext, attribute, mleader or linear dimension, like Lee Mac’s "LengthField").
6. Repeat steps 1-5 or exit.
Field code:
%%).Delta \f "%pt2">%/%%).Delta \f "%pt1">%)) \f "%lu2%pr3%ds44%ct8[0.2]">%
Sorry, I'm very bad at speaking English. I am hope for your help.
Sorry, this is not what I need. It's too complicated.
If I already have "Object Id", then how to write a function "strcat" correctly with my field?
this is merely a string substitute example - for testing your field expression
(setq id "[color="purple"]2123776032[/color]") [color="green"]; assumed is your "object Id" or (setq id (itoa (vla-get-objectId obj)))   [/color]
(setq str (getstring t "[color="purple"]\nPaste field expression here : [/color]" ))
([color="blue"]vl-string-subst[/color] [b]id[/b] "[color="purple"]xxxxxxxxxx[/color]" [b]str[/b] )
Use the functions from lines 429-478 of the code for this program in the following way:
(strcat
   "%<\\AcExpr (abs (%<\\AcObjProp Object(%<\\_ObjId "
   (LM:objectid <your-vla-object>)
   ">%).Delta \\f \"%pt2\">%/%<\\AcObjProp Object(%<\\_ObjId "
   ">%).Delta \\f \"%pt1\">%)) \\f \"%lu2%pr3%ds44%ct8[0.2]\">%"
Thank you, Great Lee Mac. I'm trying, but... I'm very dumb. Very.
If you could write the full code, then my joy would be absolute. I really hope for your help. Thanks again.
