nikson Posted June 7, 2018 Posted June 7, 2018 Hello. I have problem in object (line) properties. Can not set dashed line type scaling in model view. Not happend nothing when changing value. Short lines stay the same size. I change value in ltscale,psltscale...autocad 2007 Thanks for answer. Sent from my Redmi 3 using Tapatalk Quote
pendean Posted June 7, 2018 Posted June 7, 2018 What are your settings for the following variables: LTSCALE MSLTSCALE CELTSCALE Quote
nikson Posted June 8, 2018 Author Posted June 8, 2018 What are your settings for the following variables:LTSCALE MSLTSCALE CELTSCALE LTSCALE 1MSLTSCALE unknown command CELTSCALE 1 On model view have line shorten otherwise on paper view wider Thanks Sent from my Redmi 3 using Tapatalk Quote
pendean Posted June 8, 2018 Posted June 8, 2018 Share your DWG file here with the problem zoomed in view please. Quote
tombu Posted June 8, 2018 Posted June 8, 2018 See also: http://www.cadtutor.net/forum/showthread.php?102842-Working-with-linetype-scales http://www.cadtutor.net/forum/showthread.php?104228-Linetype-Scale-Headache http://www.cadtutor.net/forum/showthread.php?104223-Linetype-wont-show-on-specific-system Quote
SLW210 Posted June 11, 2018 Posted June 11, 2018 There are 2 .lin files that come with AutoCAD, acad.lin and acadiso.lin, for Imperial and Metric, respectively. Post an example drawing and end all doubt. Quote
