DDJL Posted June 8, 2018 Posted June 8, 2018 By changing the numbers at the end first Diesel code of I can pass a part of the layout name to a field for a sheet number. $(substr,$(getvar,ctab),$(-,$(strlen,$(getvar,ctab)),0),1) By naming a layout tab "1" or "2" I can use the second Diesel code to select between two different addresses and pass one or the other to an address field. $(if,$(eq,$(getvar,ctab),1),"building 1",$(if,$(eq,$(getvar,ctab),2),"building 2")) Is it possible to combine the first Diesel code with the second Diesel code so that I can use the first part of ONE layout tab to select a sheet number field, and the end part of the SAME layout tab would act as a pointer to select an address? For example if the layout tab text was "A-1 1" then the sheet number would be "A-1" and the address field would be "building 1". Quote
zaphod Posted June 8, 2018 Posted June 8, 2018 Yes, here is a drawing with an example of only the fields. A-1 1.dwg Quote
tombu Posted June 10, 2018 Posted June 10, 2018 Lee Mac has something you should take a look at: http://www.lee-mac.com/layoutfield.html Quote
DDJL Posted June 14, 2018 Author Posted June 14, 2018 ZAPHOD You pointed me in the right direction and helped me solve my problem Thanks DDJL Quote
