gmmdinesh Posted June 12, 2018 Posted June 12, 2018 Hi Everyone I have to draw a elevation view as per dimensions, but i need to draw the view with two scale. For horizontal 1:500 and vertical 1:200. Really I don't have an idea how to do this. Please anyone help me. And also please explain briefly about scale.. If i want to draw 10m line on 1:200 scale...can i draw for 10m or need to some calculations for that? Thanks in advance Quote
ReMark Posted June 12, 2018 Posted June 12, 2018 Create a grid based on the two scales similar to what one might do if drawing a sewer profile. Quote
gmmdinesh Posted June 12, 2018 Author Posted June 12, 2018 But. I have change the size of the scale bar using scale command.. Quote
guran Posted June 12, 2018 Posted June 12, 2018 Draw the view as you normally do, make a block of it and then insert the block. When interting the block, you can specify the scale for X and Y separately. Quote
