Hello all,
Is it possible to make certain objects associated with each other?
For example:
I pick two points.
A line is drawn between those points.
A block is placed on the end of the line.
All the above i can code without any problem...
But...
Now when i move this block, i want the end of that line to move with it...
Would this be possible?
Maybe an idea if you set up a dimension style that is a line only everything else turned off and make it associate with the two points.
Thanks for the suggestions,
I managed to build something i needed. :-)
Instead of making objects associative, i used a command reactors (command start and object modified) to get the old location of the block and the new location of the block. :-)
