You could just type "plan" and hit enter, which will alter the screen to line up with the current UCS
Maybe Steven, if the dwg is tru co-ords then pick a line that you want as the e-w axis, just do UCS OB "pick line left side", I also recommend extra UCS S "viewname" if you open a layout tab and mview again UCS R "viewname" PLAN then set the scale and all done, you can change the Model view as well if you want by typing PLAN to accept the ucs you have just set.
