dhananjay567 Posted April 14, 2018 Posted April 14, 2018 In Model I have drawn 45 degree line, want this line in layout as a strait line , & same time, Layout double clicking i have drawn strait line, this line will shows 45 degree in Model. please give me suggestion how can i do this. Quote
ReMark Posted April 14, 2018 Posted April 14, 2018 Wouldn't you have to rotate your viewport (in the layout) negative 45 degrees to make it appear as though the line back in model space was straight and not drawn at an angle? As for the second part of your question I have no idea. What exactly are you trying to accomplish? Quote
BIGAL Posted April 14, 2018 Posted April 14, 2018 UCS OB pick line left end, UCS S giveitaname, got to layout inside mview UCS R giveitaname Plan all done. This way world stays real but viewport is rotated. Quote
Deodar311 Posted April 19, 2018 Posted April 19, 2018 I would add setting UCSFOLLOW (1). This command sets your cursor horizontal/vertical to the page. UCSFOLLOW keeps the cursor either parallel to the screen or parallel to the UCS. Play around with it and see what you think. I find it very handy when rotating the UCS. Also, I make sure SNAPANG is set to 0. Quote
guran Posted April 19, 2018 Posted April 19, 2018 Orient the UCS after the line you want horizontal, type "Plan" and then ENTER Quote
dhananjay567 Posted June 24, 2018 Author Posted June 24, 2018 I have drawn a Line 5m lenghth @ angle 45 deg. in model space. Want to print it as 5m Length @ angle 0 deg. in Layout. if i have draw straight line (0 deg.) in Layout, it will be seen 45 deg. in Model space. please help How to do it. Regards Dhananjay Quote
dhananjay567 Posted June 24, 2018 Author Posted June 24, 2018 want model space no change in UCS, but in Layout it will be seen rotated. & vice versa. Quote
BIGAL Posted June 25, 2018 Posted June 25, 2018 Read my post again an option in using the command "UCS" is to pick an OBject then save that UCS with a name make a viewport and do UCS R the new view name that you saved then type PLAN and set scale all done. Quote
hanhphuc Posted June 25, 2018 Posted June 25, 2018 (edited) no sure, FWIW Command: DVIEW Select objects or : 1 found Enter option [CAmera/TArget/Distance/POints/PAn/Zoom/TWist/CLip/Hide/Off/Undo]: TW Specify view twist angle : 45 or express tool ? (c:alignspace) ? Edited June 25, 2018 by hanhphuc screen shot added Quote
