i am using lee-mac lisp "Areas2FieldV1-3", its calculate the area of object and print it to text.
i managed to add prefix and suffix to the lisp. now its looks like that when i choose an object it shows a=xm2.
i need to add increment number to my result, for example a1=xm2 to the first object a2=xm2 to the second object and so on.
how do i do that?
Hi,
(setq IncNum 0) ;; add this line of codes at the top above the iteration of objects to avoid repetition of the same value.
(strcat "a" (itoa (setq IncNum (1+ IncNum))) ".......m2")
hi, thanks for the reply
i am new to this, and i really don't get it, sorry.
i hope you can help me
here is the code:
;;------------------------=={ Areas to Field }==------------------------;;
;;  This program allows a user to create an MText object containing a   ;;
;;  Field Expression referencing the area, or sum of areas, of one or   ;;
;;  more selected objects.                                              ;;
;;  Upon issuing the command syntax 'A2F' at the AutoCAD command-line,  ;;
;;  the user is prompted to make a selection of objects for which to    ;;
;;  retrieve the area; if more than one object is selected, the         ;;
;;  cumulative area for all objects will be displayed by the resultant  ;;
;;  MText Field.                                                        ;;
;;  Following object selection, the user is prompted to pick a point    ;;
;;  at which to create the MText Field. If the specified point resides  ;;
;;  within an AutoCAD table cell, the program will populate the table   ;;
;;  cell with the appropriate Field Expression.                         ;;
;;  The Field will display the sum of the areas of the selected         ;;
;;  objects, formatted using the Field formatting code specified at     ;;
;;  the top of the program - this formatting code may be altered to     ;;
;;  suit the user's requirements.                                       ;;
;;  Author:  Lee Mac, Copyright © 2014  -  www.lee-mac.com              ;;
;;  Version 1.3    -    2014-07-17                                      ;;
(defun c:a2f ( / *error* fmt inc ins lst sel str )
(setq IncNum 0)
   (setq fmt "A=%lu6%pr1 m²") ;; Field Formatting
   (defun *error* ( msg )
       (LM:endundo (LM:acdoc))
       (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
   (if (and (setq sel (ssget '((0 . "ARC,CIRCLE,ELLIPSE,HATCH,*POLYLINE,REGION,SPLINE"))))
            (setq ins (getpoint "\nPick point or cell for field: "))
           (if (setq tmp
                   (ssget "_X"
                       (list '(0 . "ACAD_TABLE")
                           (if (= 1 (getvar 'cvport))
                               (cons 410 (getvar 'ctab))
                              '(410 . "Model")
               (repeat (setq idx (sslength tmp))
                   (setq tab (cons (vlax-ename->vla-object (ssname tmp (setq idx (1- idx)))) tab))
           (if (= 1 (sslength sel))
               (setq str
                   (strcat
                       "%<\\AcObjProp Object(%<\\_ObjId "
                       (LM:ObjectID (vlax-ename->vla-object (ssname sel 0)))
                       ">%).Area \\f \"" fmt "\">%"
                   (repeat (setq idx (sslength sel))
                       (setq lst
                           (vl-list*
                               (LM:ObjectID (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))))
                               ">%).Area>%" " + "
                               lst
                   (setq str
                       (strcat
                           "%<\\AcExpr "
                           (apply 'strcat (reverse (cdr (reverse lst))))
                           " \\f \"" fmt "\">%"
           (LM:startundo (LM:acdoc))
           (if (setq tmp (LM:getcell tab (trans ins 1 0)))
               (apply 'vla-settext (append tmp (list str)))
               (vla-addmtext
                   (vlax-get-property (LM:acdoc) (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace))
                   (vlax-3D-point (trans ins 1 0))
                   0.0
                   str
;; ObjectID  -  Lee Mac
;; Returns a string containing the ObjectID of a supplied VLA-Object
;; Compatible with 32-bit & 64-bit systems
(defun LM:ObjectID ( obj )
   (eval
       (list 'defun 'LM:ObjectID '( obj )
           (if
               (and
                   (vl-string-search "64" (getenv "PROCESSOR_ARCHITECTURE"))
                   (vlax-method-applicable-p (vla-get-utility (LM:acdoc)) 'getobjectidstring)
               (list 'vla-getobjectidstring (vla-get-utility (LM:acdoc)) 'obj ':vlax-false)
              '(itoa (vla-get-objectid obj))
   (LM:ObjectID obj)
;; Get Cell  -  Lee Mac
;; If the supplied point lies within a cell boundary,
;; returns a list of: (<VLA Table Object> <Row> <Col>)
(defun LM:getcell ( lst pnt / dir )
   (setq dir (vlax-3D-point (trans (getvar 'viewdir) 1 0))
         pnt (vlax-3D-point pnt)
   (vl-some
      '(lambda ( tab / row col )
           (if (= :vlax-true (vla-hittest tab pnt dir 'row 'col))
               (list tab row col)
       lst
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
   (LM:endundo doc)
   (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
   (while (= 8 (logand 8 (getvar 'undoctl)))
       (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
   (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
   (LM:acdoc)
(vl-load-com) (princ)
;;                             End of File                              ;;
