amb2301 Posted June 26, 2018 Posted June 26, 2018 Hi Friends, i need a lisp to select the block name called "xxx_box" from the current drawing, i need in such a way to select block only by Qselect method, please help me friends. Quote
rkmcswain Posted June 26, 2018 Posted June 26, 2018 How about this? (sssetfirst nil (ssget "_x" '((0 . "Insert")(2 . "xxx_box")))) Quote
amb2301 Posted June 26, 2018 Author Posted June 26, 2018 Awesome, its working like a charm, thank you so much rkmcswain Quote
amb2301 Posted June 26, 2018 Author Posted June 26, 2018 i need one help rkmcswain, i am doing a manual work(annotating) in following way... 1. click on the macro button from the tool bar 2. need to press the right side arrow key 5 times & hit enter key 3. then go to current modelspace & click near that block. requesting to please help me on this task. please let me know your requirements, can i post it as a new thread? Quote
BIGAL Posted June 27, 2018 Posted June 27, 2018 Back to 1st task adding a bit more auto load this (defun pb ( bname / ) (sssetfirst nil (ssget "_x" (list (cons 0 "Insert")(cons 2 bname)))) ) To use just type on command line (pb "Blockname") Quote
BIGAL Posted June 27, 2018 Posted June 27, 2018 amb2301 please explain what it is you are doing arrow 5 times ? some screen grabs maybe. 1st suggestion do item 3 1st not last. Quote
amb2301 Posted June 27, 2018 Author Posted June 27, 2018 Hi Bigal, Thank you so much for your suggestions, as you said i just need to do screen grab(just need to select options by pressing arrow keys), i tried a similar lisp from cadtutor, but its not working, could you please help me on that (defun c:box () (sssetfirst nil (ssget "_x" '((0 . "Insert")(2 . "XXX_BOX")))) (command "Pdm") (command "execute_settings") (command "XXXXXX_ANNO_CNTRL") (command "annotate") (defun test ( ) (LM:sendkeys "{RIGHT}") (princ)) (defun test ( ) (LM:sendkeys "{RIGHT}") (princ)) (defun test ( ) (LM:sendkeys "{ENTER}") (princ)) ;; Send Keys - Lee Mac ;; A wrapper function for the SendKeys method of the WSH (defun LM:sendkeys ( keys / wsh ) (setq wsh (vlax-create-object "WScript.Shell")) (vl-catch-all-apply 'vlax-invoke (list wsh 'sendkeys keys)) (vlax-release-object wsh) (princ) ) (vl-load-com) (princ) ) Quote
BIGAL Posted June 28, 2018 Posted June 28, 2018 I think we all need to take a few steps back and for you to explain what is it your trying to do, you need to press arrows but to what ? Is it all inside some other program ? PDM PDMODE Enter new value for PDMODE : what happens now ? Quote
amb2301 Posted June 29, 2018 Author Posted June 29, 2018 Hi All, There is a third party application making AutoCAD work with a separate Spatial Database. But its API does not expose all the functions that I need which prevents me from working full blast without using interactive sendkeys. My task is this: users can work with it manually but it is taking to much time so I need to automate their repetitive task of interactively clicking on each of those dialog boxes that the 3rd party application uses. Third party application creates a drop down menu addition to the standard AutoCAD menu. And that drop down menu is where I am supposed to start the automation process. I am trying to trigger a series of about 10 sendkeys statements which I am trying to run from lisp / VBA. What I notice with said sendkeys series of statements is it seems to be able to execute the first sendkeys call as I intended it, i.e. pop out a dialog box but then the -- 2nd to the 10th sendkeys call all end up on the command line instead of going to the dialog box (popped out by my first sendkeys statement) of which I intended all the those sendkeys statements to go. The command buttons are not triggerable from the command line of AutoCAD -- so I really have no choice but to try to manipulate those command buttons using sendkeys. Please help me with any idea you have in mind. Quote
