code that select all object and convert in to mentioned layer
Hello every one i need help on completing below code.
Basically i need code that select objects and after selecting objects convert layer "obj2" into "obj1" layer and "dim" into "0" layer
(defun c: autolayerchange ()
(if (setq ss (ssget))
(prong (setq i (1- (sslength ss)))
(while (
(setq e (ssname ss i)
x (cdr (assoc 8 (entget e)))
i (1- i)
) ; it is returning object layer name
(foreach x "obj2" convert to layer "obj1")
(foreach x "dim" convert to layer "0")
i am stuck at red marked text. thank you for your help
  • Replies 20
  • Solitechcadsolutions
    8
  • Tharwat
    3
  • satishrajdev
    3
  • Grrr
    3
Something like this?
(defun c:test ( / e i l ss)
 (if (setq ss (ssget))                       [color="red"]; <- add your ssget filter here[/color]
     (setq e (entget (ssname ss (setq i (1- i)))))
     (setq l (cdr (assoc 8 e)))
     (cond ((eq l "obj2") (entmod (subst (cons 8 "obj1") (assoc 8 e) e)))
    ((eq l "dim") (entmod (subst (cons 8 "0") (assoc 8 e) e)))
Another:
(defun c:autolayerchange ( / _in _ss _obj)
 (if
   (setq _ss (ssget (list (cons 8 "obj2,dim"))));; <- change your ssget filter
   (repeat (setq _in (sslength _ss))
     (setq _obj (vlax-ename->vla-object (ssname _ss (setq _in (1- _in))))); get
     (if (= (vla-get-layer _obj) "obj2")
       (vla-put-layer _obj "obj1")
       (vla-put-layer _obj "0")
i added layer selection filter but its not working...
Another:
(defun C:AutoLayerChange ( / L _LayersList _Recapitalise lyrs SS i enx lyr tmp )
 (setq L ; Note: layer names are case insensitive - assoc list of: (<old layer> . <new layer>)
   '( ; Place your inputs here:
     ("obj2" . "obj1")
     ("dim" . "0")
   ); list
 ); setq L
 (defun _LayersList ( / d L )
   (while (setq d (tblnext "LAYER" (not d)))
     (setq L (cons (cdr (assoc 2 d)) L))
 (defun _Recapitalise ( itm L )
   (vl-some (function (lambda (x) (if (= (strcase itm) (strcase x)) x))) L)
 (and
   (setq lyrs (_LayersList))
   (or
     (setq L (apply (function append) (mapcar (function (lambda (x / tmp) (if (setq tmp (_Recapitalise (car x) lyrs)) (list (cons tmp (cdr x)))))) L)))
     (prompt "\nNo valid layers were found.")
   ); or
   (or
     (prompt "\nSelect objects to change layers: ")
     (setq SS (ssget "_:L-I" (list (cons 8 (setq tmp (substr (apply (function strcat) (mapcar (function (lambda (x) (strcat "," (car x)))) L)) 2))))))
     (prompt (strcat "\nNo objects were found on \"" tmp "\"  layers."))
   ); or
   (repeat (setq i (sslength SS))
     (setq enx (entget (ssname SS (setq i (1- i)))))
     (setq lyr (assoc 8 enx))
     (entmod (subst (cons 8 (cond ( (cdr (assoc (setq tmp (cdr lyr)) L)) ) ( tmp ) )) lyr enx))
   ); repeat
 ); and
); defun C:AutoLayerChange
What objects are you trying to select? Post your code here so that we can check it
(if (setq ss (ssget (list (cons 8 "dim,obj2")))) ;
it is not working ...
and code which is shared by ziele is working but it is converting both layer to "0" layer it should converted (obj2 to obj1 and dim to 0)
Another:
     ("obj2" . "obj1")
     ("dim" . "0")
   ); list
 ); setq L
 (and
   (or
   ); or
   (or
   ); or
   ); repeat
 ); and
working for me thank you... but need to understand your code :)
This code working fine at my end. Please check properly.
I checked zilele's code also that also works fine. something is wrong are your end
Well sathish I am sorry but its not working on my pc .. I tried many times... if you could help me on this ...
Hi Grrr,
I think you need to exclude the VIEWPORT object from the selection set since you have used the entmod function besides that, you don't need to search if the target layer is found or existed since the cons function could create that target layer name with default values.
Hi Grrr,
Hi Tharwat,
Thanks for the advices.. I have one question regarding the VIEWPORT:
Wheres a case for the user to select a VIEWPORT object? When working in paperspace (my guess) ?
I always work in modelspace, so I never regarded the possibility for this issue. :geek:
BTW for the second remark, I actually don't look if the targed layer already exists - just making sure if OP provides list of dotted pairs:
'( ; The routine will skip entmod'ing "Layer1"
 ("obj2" . "obj1")
 ("dim" . "0")
 ("Layer1")
But I agree its a bit inefficient to entmod with the same layer.
will take care of this next time thank you for your reminder.
Hi Tharwat,
We can't guess that all users work from / in Model space.
Agree with that but that would ignore moving objects to targeted layer if its not existed and that is the point.
Hope that my comment did not make any confusion.
Hi Grrr,
tharwat if you could help on sathish's code why it is not working on my system ? any thoughts ?
test
Solitechcadsolutions, you need to describe your goal of the program very clearly to all members whom wanting to help you and write the correct codes for that purpose.
For instance;
What are the objects that you are trying to move them to that new layer name?
Would you like to select certain objects or let the program select them all?
Do you have the objects on unlocked layers?
And so on.
I agree with the use of an association list, but the code could be greatly simplified, for example -
(defun c:laymap ( / enx idx lay map sel )
   (setq map
       (mapcar '(lambda ( x ) (cons (strcase (car x)) (cdr x)))
               ("obj2" . "obj1")
               ("dim"  . "0")
   (if (setq sel (ssget "_:L" (append '((-4 . "<OR")) (mapcar '(lambda ( x ) (cons 8 (car x))) map) '((-4 . "OR>")))))
       (repeat (setq idx (sslength sel))
           (if (setq idx (1- idx)
                     enx (entget (ssname sel idx))
                     lay (cdr (assoc (strcase (cdr (assoc 8 enx))) map))
               (entmod (subst (cons 8 lay) (assoc 8 enx) enx))
Nice one Lee,
I didn't realise you could filter the layers like that, with ignoring the case of their names! :thumbsup:
thank you lee and grr that codes are working nicely for me .... :)
Great
