Printing a variable to the command line??
Is there a way to print the value of a variable to the command line?
For instance, I am going through a loop and for each entity in my selection set I am inserting a new block with info from the other blocks that make up the selection set. But what I want to do is before every new block is inserted, change a variable but I have to prompt the user....
(setq Curquan (getstring "\n Enter quantity for part number"))...etc, etc, etc,
I already have a "PNUM" variable that holds the current number I wish to show up on the command line but I cant figure out how to get it to print on a single line like I want it to.
I want the command line output to be...
"Enter quantity for part number 123456:"
Any suggestions?
If you are prompting for a "quantity" it is probably better to be using "getreal" or "getint".
If you want to use your previously stored variable in the string:
(setq Curquan (getstring (strcat "\nEnter quantity for part number" (rtos PNUM) ": ")))
Hope this helps :)
LEE!
The strcat function is exactly what I needed.
Thanks for the tidbit. It seems like everyday I find something new in my programming that opens up all kinds of doors.
My command is growing bigger everyday and as soon as I get it done I will post it to to share so maybe someone can get some help from me someday.
Cheers.:D
No Probs Hard Eight, I'm sure you'll get the hang of it - the hardest part is remembering which commands do what :P
i just have have trouble remembering
