AlexP Posted July 9, 2018 Posted July 9, 2018 Hi Designers, I would like to have a lisp that reads the Description of a Block and shows it on a Multileader so then you don't have to type in the Text once a Block is registered. I know this topic was covered in an much older post before - almost 10 years ago - but I put hours experimenting with the Lisp in different ways and still couldn't get it to work 100%. http://www.cadtutor.net/forum/showthread.php?39301-Block-into-multileader-text Does anyone have the solution to this? Quote
Emmanuel Delay Posted July 10, 2018 Posted July 10, 2018 Here is what I wrote: - the client selects a block (I assume it has a description, I assume the client clicks on a block ... no anti dummy protection) - the client must now draw the MLeader: two points: arrow head + leader landing - The routine will fill in the caption, being the description of the block. Command: SAD (pun maybe intended, although it's just an abbreviation) (defun getBlockProperties ( #Entsel / ) (setq #Entsel (vlax-ename->vla-object (car #Entsel)) ;; insertion point #InsPoint (vlax-safearray->list (vlax-variant-value (vla-get-InsertionPoint #Entsel) ) ;_ vlax-variant-value ) ;_ vlax-safearray->list ;; block name #Name (vla-get-name #Entsel) ;; block description #Desc (vla-get-comments (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)) ) ;_ vla-get-blocks #Name ) ;_ vla-item ) ;_ vla-get-comments ) ;_ setq (list #Name #InsPoint #Desc) ) ;; create Mleader with caption. (defun wmt (caption / ) ;;(vl-cmdf "_.MLEADER" PAUSE PAUSE "" "_.TEXTEDIT" "_L") (vl-cmdf "_.MLEADER" PAUSE PAUSE caption) ) ;; Select And get Description (defun c:sad ( / desc) (setq desc (nth 2 (getBlockProperties (entsel "\nSelect a block: ")))) (princ "\nNow draw the MLeader:\n") (wmt desc) (princ) ) Happy with this? Quote
AlexP Posted July 10, 2018 Author Posted July 10, 2018 Almost ! It identifies the Description, but won't fill in the caption. Quote
Tharwat Posted July 10, 2018 Posted July 10, 2018 The simplest I guess. (defun c:d2ml ( / s d) (and (princ "\nPick a block :") (setq s (ssget "_+.:S:E" '((0 . "INSERT")))) (or (setq d (cdr (assoc 4 (entget (tblobjname "BLOCK" (cdr (assoc 2 (entget (ssname s 0))))))))) (alert "Block does not have a description <!>") ) (vl-cmdf "_.Mleader" "\\" "\\" d) ) (princ) ) Quote
AlexP Posted July 10, 2018 Author Posted July 10, 2018 Same result. I don't know why it won't put in the Description.. Quote
Tharwat Posted July 10, 2018 Posted July 10, 2018 Same result. I don't know why it won't put in the Description.. Can you post a drawing including the block? Quote
Tharwat Posted July 10, 2018 Posted July 10, 2018 Just this a go and let me know. (defun c:d2ml ( / s d l n e) (and (princ "\nPick a block :") (setq s (ssget "_+.:S:E" '((0 . "INSERT")))) (or (setq d (cdr (assoc 4 (entget (tblobjname "BLOCK" (cdr (assoc 2 (entget (ssname s 0))))))))) (alert "Block does not have a description <!>") ) (setq l (entlast)) (vl-cmdf "_.Mleader" "\\" "\\" "") (and (not (= l (setq n (entlast)))) (entmod (subst (cons 304 d) (assoc 304 (setq e (entget n))) e)) ) ) (princ) ) Quote
AlexP Posted July 10, 2018 Author Posted July 10, 2018 You are a Legend Tharwat !! It's works perfectly, many thanks for that ! And you Emanuel for giving it a go, I appreciate it. Quote
Tharwat Posted July 10, 2018 Posted July 10, 2018 You are a Legend Tharwat !! It's works perfectly, many thanks for that ! Thanks for the nice words AlexP. You are welcome anytime. Quote
