In my drawing there are lot of groups. By selecting through a window it can add to a selection set. After that how can I identify groups . I need filter groups in to a new selection set. Please help me.
Here is one example from Autodesk forums. Return a list of group names.
(setq  doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for group (vla-get-groups doc)
(setq return (cons (vla-get-name group) return))
(mapcar 'strcase (reverse return))
Thanks Mr Bigal
hi, just to make sure 'ACAD_GROUP' not 'PICKSET' (selection set)?
previous post titled 'group' but at the end solution was using 'selection set' :?
my understanding about group 'selection' :unsure:
FWIW, Lee Mac's ssget tutorial mentioned regarding Group - 'G'
Although a valid ssget mode string, there is no provision for passing group names as arguments to the ssget function and hence this option is only of use at the command-line during the Select objects prompt.
Command: SELECT
Select objects: [b]G[/b]
Enter group name: A
4 found
Select objects:
Command: SELECT
Enter group name: B
2 found
Select objects:
Command: SELECT
Enter group name: A,B
6 found
