I am trying to write a code to extract the dimscale of an existing dimension by picking it.
I have tried using "assoc" without any results.
Any help will be welcomed
  • Replies 21
  • CAB
    8
  • ebrito
    7
  • Lee Mac
    6
  • CarlB
    1
Give this a shot.
(defun c:dsf (/ ent obj)
 (vl-load-com)
 (and
   (or (setq ent (entsel "\nSelect dimension to get Scale Factor."))
       (prompt "\nNothing selected."))
   (setq obj (vlax-ename->vla-object (car ent)))
   (or (vlax-property-available-p obj 'ScaleFactor)
       (prompt "\nNo scale factor."))
   (print)
   (princ (vla-get-ScaleFactor obj))
Thanks But I get this message after loading "error: extra right paren on input"
I tried to fix it without success.
The code should work as is - I have just tested it.
The error that you are encountering means there is an extra ")" - possibly one that you have accidentally typed?
You are right I missed the first "(" whwn copying.
Thanks a lot.
I modify your code to select a dimension "dimscale" and "layer" to have a lisp to place continued dimensions in the selected layer and dimscale, using the selected dimension as a base.
I tried several command combinations without successes.
I am new to lisp and all help is welcomed
(defun c:dlcon (/ ent obj)
(vl-load-com)
(and
(or (setq ent (entsel "\nSelect Base Dimension"))
(prompt "\nNothing Selected"))
(print)
;(princ (vla-get-ScaleFactor obj))
(setq a (vla-get-ScaleFactor obj))
(setvar "dimscale" a)
(setq X (cdr (assoc 8
(entget (car ent)))))
(command ".layer" "set" X "")
;In this section I want to have a command to place continued dimensions
;in the selected layer and dimscale, using the selected dimension as a base.
;I tried several command combinations without successs.
(COMMAND "LAYER" "SET" "0" "")
Are you trying to run the DIMCONTINUE command with user selections?
Or are you trying to select dimensions to update with layer & scale factor?
I am trying to run dimcontinue with user selections.
In other words to have continued dimensions with the "dimscale" of the selected dimension placed in the layer of such selected dimension.
See how this works for you. (Not perfect.)
 (vl-load-com)
 (if (and
     (setq cds (getvar "dimstyle"))
     (setq clay (getvar "clayer"))
     (command ".-dimstyle" "restore" (vla-get-StyleName obj))
     ;;(setvar "dimscale" (vla-get-ScaleFactor obj))
     (setvar "clayer" (vla-get-Layer obj))
     (vl-catch-all-apply
              'vl-cmdf (list "._dimcontinue" "_S"))
     (while (> (getvar "CMDACTIVE") 0)
       (command pause)
     (command ".-dimstyle" "restore" cds)
     (setvar "clayer" clay)
Yes it works, but the semicolons in :
have to be erased in order to get de dimscale of the picked dimension.
The only issue that is not "perfect" is that the dimension has to be picked twice to start.
A very good feature is that, the dimensions can be continued to the side of the pick, regardless of the direction in which the original was drafted.
Thanks a lot I wish some day I´ll be able to write as "imperfect" as you.
What are to prompts at the command line when you enter dimcontinue as a command? And after you add one dimension with the command?
I suppose you could do it like this:
 (vl-load-com)
 (if (and
     (vl-catch-all-apply
              'vl-cmdf (list "._dimcontinue" "_S" ent))
       (command pause)
CAB,
A quick question -
Upon dissecting your LISP - I cannot find any such
vla-get-...xxx
functions in the AutoLISP Reference Manual, only
vlax-get-property
How do you use these vla-get-xxx functions?
Cheers
Lee
At te command line the prompt are:
Command: _dimcontinue
Specify a second extension line origin or [undo/Select]
( autocad displays a dim line attached to the last placed )
(If select is chosen, any dimension can be picked and it starts again fron that dimension)
Select continued dimension:
Use this code to get the properties:
(defun c:dump (/ ent obj)
 (while (setq ent (entsel "\nSelect entity to get object data: "))
   (print)
   (vlax-dump-object obj t)
   (vlax-release-object obj)
   (princ "\n")
Here I selected a line:
Select entity to get object data: ; IAcadLine: AutoCAD Line Interface
; Property values:
;   Angle (RO) = 6.25243
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00ac8928>
;   Color = 256
;   Delta (RO) = (73.8932 -2.2736 0.0)
;   Document (RO) = #<VLA-OBJECT IAcadDocument 061ffce4>
;   EndPoint = (-21.5502 -543.097 0.0)
;   Handle (RO) = "B187"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 068c7ea4>
;   Layer = "LayerName"
;   Length (RO) = 73.9281
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 106617208
;   ObjectName (RO) = "AcDbLine"
;   OwnerID (RO) = 105390096
;   PlotStyleName = "ByLayer"
;   StartPoint = (-95.4433 -540.823 0.0)
;   Thickness = 0.0
;   Visible = -1
; Methods supported:
;   ArrayPolar (3)
;   ArrayRectangular (6)
;   Copy ()
;   Delete ()
;   GetBoundingBox (2)
;   GetExtensionDictionary ()
;   GetXData (3)
;   Highlight (1)
;   IntersectWith (2)
;   Mirror (2)
;   Mirror3D (3)
;   Move (2)
;   Offset (1)
;   Rotate (2)
;   Rotate3D (3)
;   ScaleEntity (2)
;   SetXData (2)
;   TransformBy (1)
;   Update ()
Note that you can modify any Property that is not (RO) Read Only
by using (vla-put- obj).
You can get any of the properties.
Ahhh, That is fantastic CAB - I can see now the allure of VL over Common LISP - I suppose getting a property using VL is so much easier than going through the palava of DXF Group Tables... :mrgreen:
And thanks for the Link - very interesting reading on the two methods.
I'm sorry to bother you further, but, why do you have to use:
vlax-release-object
I have read the ACAD help file and understand that the object cannot be accessed through the variable assigned to it (hope thats correct), but surely the value of this variable is erased by localising it in the main function:
Just curious.. :whistle:
