Dear all,
I am looking for a lisp for Sum of Length for selected PolyLines and Lines by their Linetype.
E.g.:
LineType.....Length
Cu10-6.......25.0
Cu12-6.......20.0
Cu16-6.......0.0
Cu16-10......35.0
Cu18-10......12.0
Cu22-10......10.0
Or in csv format, to be able to copy/export it to excel
This is code by lee-mac and I have added a bit to it its nearly there but I need some time to fix.
Grrr bylayer has no assoc 6
;;  Displays the total length of selected objects at the      ;;
;;  command line.                                             ;;
;;--------------------=={ Total Length }==--------------------;;
;;  Author: Lee Mac, Copyright © 2010 - www.lee-mac.com       ;;
(princ "\nType Tlen to run")
(defun c:tLen ( / lts lt)
 ;; © Lee Mac 2010
(setq lts (list "Cu10-6" "Cu12-6" "Cu16-6" "Cu16-10" "Cu18-10" "Cu22-10" ))
(repeat   (setq x (length lts))
 (setq lt (nth (setq x (- x 1)) lts))
   (lambda ( SelSet Total i / entity )
     (if SelSet
       (princ
         (strcat "\nTotal Length: "
           (rtos
             (while (setq entity (ssname SelSet (setq i (1+ i))))
               (setq Total
                   (vlax-curve-getDistAtParam entity
                     (vlax-curve-getEndParam entity)
                   Total
   (ssget
     (list (cons 0 "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")(cons 6 lt)
       (cons -4 "<NOT")
         (cons -4 "<AND")
           (cons 0 "POLYLINE")
           (cons -4 "<OR")
             (cons -4 "&=") (cons 70 16)
             (cons -4 "&=") (cons 70 64)
           (cons -4 "OR>")
         (cons -4 "AND>")
       (cons -4 "NOT>")
   0.0 -1
;;  command line.                                             ;;
 ;; © Lee Mac 2010
     (if SelSet
       (princ
           (rtos
               (setq Total
                   Total
   (ssget
       (cons -4 "<NOT")
         (cons -4 "<AND")
           (cons 0 "POLYLINE")
           (cons -4 "<OR")
           (cons -4 "OR>")
         (cons -4 "AND>")
       (cons -4 "NOT>")
   0.0 -1
I have also modified Lee-Mac code and my working result is here:
(vl-load-com)
(defun c:tlenLT	(/ e i l s ltlist lt ltname)
;;;  (setq LTfilter "TZB*,BYLAYER")
 (setq LTfilter "*")
 (if (setq s
     (ssget
       '((0 . "ARC,CIRCLE,ELLIPSE,LINE,*POLYLINE,SPLINE")
	 (-4 . "<NOT")
	 (-4 . "<AND")
	 (0 . "POLYLINE")
	 (-4 . "&")
	 (70 . 80)
	 (-4 . "AND>")
	 (-4 . "NOT>")
;;;      vvv Generate Linetypes List from selection
     (repeat (setq i (sslength s))
(setq e	     (ssname s (setq i (1- i)))
      ltname (cdr (assoc 6 (entget e)))
(if (= ltname nil) (setq ltname "BYLAYER"))
(if (and (not (member ltname ltlist))
	 (wcmatch ltname LTfilter)
    (setq ltlist (cons ltname ltlist))		;adds linetype name to list
     )  ;;;repeat
;;;      ^^^^ Generate Linetypes List from selection
     (foreach lt ltlist
(setq l 0.0)
  (if (= ltname lt)
    (setq l (+ l
	       (vlax-curve-getdistatparam
		 e
		 (vlax-curve-getendparam e)
;;;            (princ "\nTotal Length: ")
(princ (strcat lt "," (rtos (/ l 1000.0))))
(princ "\n")
 (textscr)
Edited by Jozef13
Added code tags
implementing my tought into code..
(defun C:test ( / SS aL i e itm ltp b )
 (if
   (setq SS
     (ssget "_:L-I"
         (-4 . "<NOT")
         (-4 . "<AND")
         (0 . "POLYLINE")
         (-4 . "&")
         (70 . 80)
         (-4 . "AND>")
         (-4 . "NOT>")
     (setq aL '())
     (repeat (setq i (sslength SS))
       (setq e (ssname SS (setq i (1- i))))
       (setq itm
         (cons
           (setq ltp (cond ( (cdr (assoc 6 (entget e))) ) ( "ByLayer" ) ))
           (+ (vlax-curve-getDistAtParam e (vlax-curve-getEndParam e)) (setq b (cond ( (cdr (assoc ltp aL)) ) (0.))))
       (if (zerop b)
         (setq aL (cons itm aL))
         (setq aL (subst itm (assoc (car itm) aL) aL))
     (princ "\n============\n")
     (foreach x (vl-sort aL ''((a b) (apply '< (mapcar 'car (list a b)))) )
       (princ (car x)) (princ " : ") (princ (rtos (cdr x) 2 4))
       (princ "\n")
     (princ "============")
     (textscr)
 (if
   (setq SS
     (ssget "_:L-I"
         (-4 . "<NOT")
         (-4 . "<AND")
         (0 . "POLYLINE")
         (-4 . "&")
         (70 . 80)
         (-4 . "AND>")
         (-4 . "NOT>")
     (setq aL '())
       (setq itm
         (cons
       (if (zerop b)
       (princ "\n")
     (textscr)
Hmm... nice short code :) and well working.
 (if
   (setq SS
     (ssget "_:L-I"
         (-4 . "<NOT")
         (-4 . "<AND")
         (0 . "POLYLINE")
         (-4 . "&")
         (70 . 80)
         (-4 . "AND>")
         (-4 . "NOT>")
     (setq aL '())
       (setq itm
         (cons
       (if (zerop b)
       (princ "\n")
     (textscr)
Nice Grrr .. maybe a little addition :)
          (if (> (length al) 1)
            (princ
              (strcat "\nTOTAL : "
                      (vl-princ-to-string (apply '+ (mapcar 'cdr al)))
          (textscr)
C O D E
Thanks Ron, nice addition! :)
