Dj_T_Rex2002 Posted July 23, 2018 Posted July 23, 2018 Ok so I am no expert with LISPs but LOVE learning new stuff. I just worked with this LISP by looking at other peoples LISPs and modified mine like the bottom code. However, I do not know how to set it to fill in the Trusted Locations, Plot Style Table Search Path, AutoSave since I am thinking the (vla-put-...) part might be wrong? I have been trying different VLA paths from the list on a website and cannot make it work. Please help and thank you ahead of time. (vl-load-com) (vla-put-supportpath (vla-get-files (vla-get-preferences (vlax-get-acad-object))) (strcat "C:\\Users\\<username>\\AppData\\Roaming\\Autodesk\\AutoCAD 2018\\r22.0\\enu\\support; C:\\Users\\<username>\\AppData\\Roaming\\Autodesk\\ApplicationPlugins\\AdnPlugin-Screenshot.bundle\\Contents\\Resources; C:\\Users\\<username>\\AppData\\Roaming\\Autodesk\\ApplicationPlugins; C:\\Program Files\\Autodesk\\AutoCAD 2018\\Support; C:\\Program Files\\Autodesk\\AutoCAD 2018\\Express; C:\\Program Files\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\\Resources; C:\\Program Files\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\Windows\\2018; C:\\Program Files\\Autodesk\\ApplicationPlugins\\Autodesk FeaturedApps.bundle\\Contents\\Resources; C:\\Program Files\\Autodesk\\ApplicationPlugins\\Autodesk FeaturedApps.bundle\\Contents\\Windows\\2018\\Win64; C:\\Program Files\\Autodesk\\ApplicationPlugins\\coldwater4.bundle; C:\\Program Files (x86)\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\\Resources; C:\\Program Files (x86)\\Autodesk\\ApplicationPlugins\\Autodesk AppManager.bundle\\Contents\\Windows\\2018; C:\\Program Files (x86)\\Autodesk\\ApplicationPlugins\\Autodesk FeaturedApps.bundle\\Contents\\Resources; C:\\Program Files (x86)\\Autodesk\\ApplicationPlugins\\Autodesk FeaturedApps.bundle\\Contents\\Windows\\2018\\Win64; C:\\Program Files (x86)\\autodesk\\ApplicationPlugins\\ColdWater4.bundle; J:\\Active Projects\\Detailers\\<name>\\Misc\\LISPS; J:\\Active Projects\\Detailers\\<name>\\Misc\\LISPS\\STL Goes in the Support Folder;" ) ) ;; For Trusted Locations (vl-load-com) (vla-put-PrinterConfigPath (vla-get-files (vla-get-preferences (vlax-get-acad-object))) (strcat "X:\\Drawing Utilities\\Plot Styles;" ) ) ;; for Plot Style Table Search Path ;; for AutoSave (vl-load-com) (vla-put-QNewTemplateFile (vla-get-files (vla-get-preferences (vlax-get-acad-object))) (strcat "E:\\engaccess\\start 36.dwt;" ) ) Quote
ronjonp Posted July 23, 2018 Posted July 23, 2018 Use vla-put-PrinterStyleSheetPath for your plot style path. You also might want to append to the support paths rather than completely overwriting them. This will show you the options available: (vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-acad-object))) t) You can also set the support paths like so: (setenv "ACAD" (strcat (getenv "ACAD") ";C:\\")) Quote
BIGAL Posted July 24, 2018 Posted July 24, 2018 Have a look at this should have all you want includes trusted paths and menus. ; resets the paths usefull for update versions of Autocad ; by A H 2011 ; This sets a reference to the install path of your product ; the gets are their for info maybe other use ; use this to find other settings ;(vlax-dump-object (vla-get-files (vla-get-preferences (vlax-get-Acad-object))) T) (vl-load-com) (defun setpaths ( / *files* doc) ; make temp directory (if (vl-file-directory-p "C:\\Acadtemp\\") (Princ "Acadtemp exists") (vl-mkdir "C:\\AcadTEMP\\") ) (setq *files* (vla-get-files (vla-get-preferences (vlax-get-Acad-object)))) ; savepath ;(vla-get-AutoSavepath *files*) (vla-put-AutoSavepath *files* "C:\\AcadTemp") ; custom icons ;(vla-get-CustomIconPath *files*)) (vla-put-CustomIconPath *files* "P:\\Autodesk\\ICONS") ; custom menu ;(vla-get-Menufile *files*)) ;(vla-put-Menufile *files* "C:\\Users\\2013XXXX") ; printers config ;(vla-get-PrinterConfigPath *files*) (vla-put-PrinterConfigPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles 2011") ; printers style sheet ;(vla-get-PrinterStyleSheetPath *files*) (vla-put-PrinterStyleSheetPath *files* "P:\\AutoDESK\\Plotting\\Plot Styles") ; printer drv's ;(vla-get-PrinterDescPath *files*) (vla-put-PrinterDescPath *files* "P:\\AutoDESK\\Plotting\\Drv") ; print spooler ;(vla-get-PrintSpoolerPath *files*) (vla-put-PrintSpoolerPath *files* "C:\\AcadTemp\\") ; template path ;(vla-get-TemplateDwgPath *files*) (vla-put-TemplateDwgPath *files* "P:\\Autodesk\\c3d Templates") ; template location ;(vla-get-QnewTemplateFile *files*) (vla-put-QnewTemplateFile *files* "P:\\Autodesk\\c3d Templates\\XXXX-2019.dwt") ;make new support paths exist + new (setq paths (vla-get-SupportPath *files*)) (setq XXXXpaths "P:\\autodesk\\supportfiles;P:\\autodesk\\lisp;P:\\autodesk\\fonts;P:\\autodesk\\hfs fonts;") (setq newpath (strcat XXXXpaths paths)) (vla-put-SupportPath *files* newpath) ; Tempdirectory ;(vla-get-TempFilePath *files*)) (vla-put-TempFilePath *files* "C:\\AcadTemp\\") ; PlotLogFilePath = "C:\\Documents and Settings\\BIGAL.XXXX-AD\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\" (vla-put-PlotLogFilePath *files* "C:\\AcadTemp\\") ; LogFilePath = "C:\\Documents and Settings\\BIGAL.XXXX-AD\\localsettings\\application data\\autodesk\\c3d 2011\\enu\\" (vla-put-LogFilePath *files* "C:\\AcadTemp\\") ; xref temp path ;(vla-get-TempXrefPath *files*)) (vla-put-TempXrefPath *files* "C:\\AcadTemp\\") ; end use of *files* (setq oldtrust (getvar 'trustedpaths)) (setq newtrust (strcat oldtrust ";" "p:\\Autodesk...")) (setvar 'trustedpaths newtrust) (command "menuload" "p:\\autodesk\\hfs Fonts\\hfs-XXXX") (menucmd "P19=+HFS.POP1") (command "menuload" "p:\\autodesk\\lisp\\surfal") (menucmd "P20=+SURFAL.POP1") (command "menuload" "p:\\autodesk\\lisp\\XXXXSTDS9") (menucmd "P21=+XXXXSTDS.POP1") (command "menuload" "p:\\autodesk\\lisp\\XXXX2011") (menucmd "P22=+XXXX2011.POP1") ) ; defun (setpaths) (alert "Run user script for toolbars") ; exit quitely (princ "All Done") Quote
