Jeremiah D Posted July 25, 2018 Posted July 25, 2018 Hello all, The routine below is marvelously handy as is, but I was hoping to get some assistance with changing it a little bit. Right now, once I'm in an active viewport I'm prompted to select an object which would ideally be a non plot rectangle around my elevation or section i wish to zoom to. It then sets the Annotation & Standard scales (based on what exactly I'm not quite sure ) What I would like to do is edit this to have the option of either selecting an object, and selecting the two corners of a zoom window. Any help is appreciated. I've only begun the plunge into seriously studying AutoLISP programming in the last few months, though i've been using it everyday for a few years—still very much a begginer. ;;;Viewport zooming & setting nearest scale routine ;;;by: Ranjit.Singh (vl-load-com) (defun c:v1 (/ cvp dat3 ent obj Lowerc Upcor etdata etdata2 sc ss1 zf) (and (zerop (getvar 'tilemode)) (> (setq cvp (getvar 'cvport)) 1) (setq ent (car (entsel "\nSelect object to zoom to: "))) (vl-cmdf "._zoom" "_o" ent "") (setq ss1 (ssget "_x" (list '(0 . "viewport") (cons 69 cvp) (cons 410 (getvar 'ctab))))) (setq zf (/ (cdr (assoc 41 (setq etdata (entget (setq ent (ssname ss1 0)))))) (cdr (assoc 45 etdata))) dat3 (mapcar '(lambda (x) (cons (cdr (assoc 300 (setq etdata2 (entget (cdr x))))) (apply '/ (reverse (cdr (reverse (mapcar 'cdr (member (assoc 140 etdata2) etdata2)))))))) (vl-remove-if-not '(lambda (x) (= 350 (car x))) (dictsearch (namedobjdict) "ACAD_SCALELIST")))) (setpropertyvalue ent "ViewHeight" (/ (cdr (assoc 41 etdata)) (cdr (assoc (setq sc (caar (vl-sort (mapcar '(lambda (x) (cons (car x) (abs (- zf (cdr x))))) dat3) '(lambda (x y) (< (cdr x) (cdr y)))))) dat3))))) (command "_.cannoscale" sc) (command "_.pspace" ) ;my only additions to Ranjit's code (command "zoom" "extents") ;my only additions to Ranjit's code (princ)) Quote
Jeremiah D Posted July 25, 2018 Author Posted July 25, 2018 edits: "...either selecting an object, *or selecting the two corners..." "...a few years—still very much a *beginner...." Quote
Jeremiah D Posted July 25, 2018 Author Posted July 25, 2018 I don't think this makes any difference functionally, but just to head off any possible confusion. I just realized there are two additional arguments in the in the list that weren't in the original. They are "Lowerc" and "Upcor". I added these when I was first messing with it and forgot to take them out. Quote
