.ipt part not showing up in Drawing file from model
Hello,
I have several models of dispenser sumps that I am working on, and there is one specific piece (a shear valve) that is very clearly in the model, however, when I place the assembly in a standard.dwg or standard.idw, the shear valve does not show up. Alternatively, when I place just the single part in a .dwg or .idw, the valve shows up perfectly. I researched the solution and found that it could be as simple as choosing the "Include All Surfaces" option on the drop down menu, however, I can not find that option on my drop down. It is not greyed out, it just doesn't show up. The valve is used in about 20 different places on this project and entire assemblies are surrounding this part! Please help!
Thank you
Rachel
