Auto select previous objects after running a defun of another routine
3dwannab
 Share
Hi,
I was hoping to LOAD a lsp file then call it via (c:runthislispfile) inside another routine to combine them in one.
Problem is, they prompt for a selection, so I thought this would work:
(command "_P")
(while (eq 1 (logand 1 (getvar 'CMDACTIVE))) (command ""))
Is this possible? I'm pretty sure it is with the cmdactive trick.
See code below and comments where the problem lies:
(defun c:---BB (/) (progn (LOAD "3dwannab_ByBlock_Change_Entities") (C:BB)))
; Change all selected entities to ByBlock and layer 0 & more.
(defun c:BB ( / ss_1 )
(setq *error* SS:error)
(SS:startundo)
(setq cmde (getvar "cmdecho"))
(setq os (getvar "osmode"))
(setq orthom (getvar "orthomode"))
(setvar 'cmdecho 0)
(setvar 'osmode 83)
(setvar 'orthomode 1)
	(setq ss_1 (last (ssgetfirst)))
	(if (not ss_1)
		(setq ss_1 (ssget '((0 . "~HATCH"))))
	(if ss_1
			(command "._chprop" "_non" ss_1 "" "_LA" "0" "")
			(command "._chprop" "_non" ss_1 "" "_LT" "BYBLOCK" "")
			(command "._chprop" "_non" ss_1 "" "_LTS" "1" "")
			(command "._chprop" "_non" ss_1 "" "_LW" "BYBLOCK" "")
			(command "._chprop" "_non" ss_1 "" "_TR" "BYBLOCK" "")
			(command "._chprop" "_non" ss_1 "" "_C" "BYBLOCK" "")
			;; How do I run the command for this lisp then select previous and run it automatically.
			;; Below doesn't work.
			;; This routine is for rounding off entities to the nearest 0.5mm.
			(prompt "\nRUN the F5 command also to round off to 0.5mm ?\n")
			(load "FX_Round_Numbers_0Point5")
				(c:F5)
				(command "_P")
			;; This is the PSIMPLE command to fix polylines. Again it prompts for a selection here.
			(prompt "\nRUN the PSIMPLE command also ?\n")
			(load "PSimple")
				(c:PSIMPLEV)
				(command "_P")
			(setq ss_1 nil)
		(princ "\nUser Cancelled Command\n")
(*error* nil)
(defun SS:error (errmsg)
(and acDoc (vla-EndUndoMark acDoc))
(and errmsg
	(not (wcmatch (strcase errmsg) "*CANCEL*,*EXIT*"))
	(princ (strcat "\n<< Error: " errmsg " >>\n"))
(setvar 'cmdecho cmde)
(setvar 'osmode os)
(setvar 'orthomode orthom)
(defun SS:startundo ()
(setq acDoc (vla-get-ActiveDocument (vlax-get-acad-object)))
(or (vla-EndUndoMark acDoc) (vla-StartUndoMark acDoc))
(vl-load-com)
(princ
(strcat
	"\n3dwannab_ByBlock_Change_Entities.lsp Loaded\n"
	"\nInvoke by typing 'BB'\n"
;;                             End of File                              ;;
Do you have the code for PSIMPLE? Does it work on preselected polylines? If so
(sssetfirst nil (ssget "P"))
should work.
another option: http://forums.augi.com/showthread.php?81175-select-result-lisp-modification#5
Sweet. I've needed this elsewhere. Thank you.
PSIMPLE's an amazing routine. Gets rid of those pesky non-closed polylines. As you can see I've called the verbose method which outputs the findings.
http://www.theswamp.org/index.php?topic=19865.msg244786#msg244786
Working code:
(defun c:BB ( / ss_1 e i )
(SS:startundo)
(setvar 'cmdecho 0)
(setvar 'osmode 83)
	(if (not ss_1)
	(if ss_1
			(repeat (setq i (sslength ss_1))
				(setq i (1- i))
				(if (= "HATCH" (cdr(assoc 0 (ENTGET (setq e (ssname ss_1 i))))))
					(SSDEL e SS_1 ))
			;; initget from LeeMac help pages
			(initget "Yes No")
			(setq ans
				(cond
						(getkword
							(strcat "\nLoad FX_Round_Numbers_0Point5 and run ?\n: --------------------------------------------------------- :\nWill round off everything to the nearest 0.5\n: --------------------------------------------------------- :\n[Yes/No] <"
								(setq ans
									(cond ( ans ) ( "Yes" ))
					( ans )
			(cond
				((=  "Yes" ans)
						(prompt "\nNow running the 0.5mm round off command also...\n-------------------------------------\n")
						(sssetfirst nil (ssget "_P"))
						(c:F5)
				((= "No" ans)
					(princ (strcat "\n: --------------------------------------------------------- :\nFX_Round_Numbers_0Point5.lsp not performed.\n: --------------------------------------------------------- :\n"))(princ)
				(setq i (1- i))
				(if (/= "LWPOLYLINE" (cdr(assoc 0 (ENTGET (setq e (ssname ss_1 i))))))
					(SSDEL e SS_1 ))
			(if (> (sslength SS_1) 0)
					(prompt "\nNow running the PSIMPLEV command also...\n-------------------------------------\n")
					(load "PSimple")
					(c:PSIMPLEV)
					(princ (strcat "\nNo LWPOLYLINEs' found.\n: --------------------------------------------------------- :\n"))(princ)
			(setq ss_1 nil)
			(command "._regenall")
(*error* nil)
(and errmsg
(setvar 'osmode os)
(vl-load-com)
(princ
(strcat
;;                             End of File                              ;;
Edited by 3dwannab
Added more to the code. An initget. And to filter HATCHES from the ssgetfirst. And to only run PSIMPLEV if LWPOLYLINES > 0.
Updated the code above. This will be a lifesaver when editing blocks. I seem to spend all my time in the block editor..!!!
And it's No, Nay, never,
No, nay never no more block editor.
 Share
