Select Block, Assign Attribute Value with Stored Variable
Try something like this:
(defun c:foo (/ _foo a b s)
 ;; RJP » 2018-08-02
 (defun _foo (b tag f)
   (vl-some '(lambda (x)
	(cond ((= (strcase tag) (strcase (vla-get-tagstring x)))
	       (if f
		 (not (vla-put-textstring x f))
		 (vla-get-textstring x)
     (vlax-invoke b 'getattributes)
 (cond
   ((and (setq s (ssget ":L" '((0 . "insert") (66 . 1))))
  (setq s (mapcar 'vlax-ename->vla-object (vl-remove-if 'listp (mapcar 'cadr (ssnamex s)))))
    ;; Enter your tagnames here
    (foreach tag [color="red"]'(("LINE-ID" "LINE_NO") ("TAGTOGETVALUE" "TAGTOPUTVALUE") ("SERVICE" "SERVICE"))[/color]
      (if (setq
     a (vl-some
	 '(lambda (x)
	    (cond
	      ((= "PID-LINE-ID" (strcase (vla-get-effectivename x))) (_foo x (car tag) nil))
	 s
 (setq b (cons (list a (cadr tag)) b))
    (foreach x s (foreach v b (_foo x (cadr v) (car v))))
Works perfectly. Once again, thanks for the help!
  • Replies 21
  • ronjonp
    10
  • atb1984
    6
  • rlx
    3
  • Grrr
    2
Glad to help :)
