set local color to object inside a nested block (without entering to block mode)
hi
i need to be able to changh the color of object that live inside a block (sometimes nasted blocks) without entering the block.
for example, i have a window block, it comes with blue as the color, i want that window to have a local color of 11, i want to do that with no need to enter the block, as said sometimes the window is nasted inside the block/
how can it be done?
THanks
Shay
(defun tst1 ( / ent col)
   (and
     (setq ent (car (nentsel "\nSelect entity to change color")))
     (setq col (acad_colordlg 0))
     (setq ent (vlax-ename->vla-object ent))
     (vlax-property-available-p ent 'color T)
     (progn (vla-put-color ent col) T)
     (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acAllViewports)
(defun tst2 ( / sel ent col)
 (and
   (setq sel (nentsel "\nSelect entity to change color"))
   (cond ((or (= 2 (length sel)) (= 1 (length (last sel))))(setq ent (car sel)))
          (T (setq ent (car (last sel)))))
opps...it wont effect my f**** block
attached
thanks
Shay
think tst1 can change the color (of a single entity) and was hoping (tst2) would do it for the entire (nested) block but sadly... also , because its a nested block , update 1 means update all. Will try to have a look later cause somebody used the W-word against me (work)
i consider marry you :)
Yeah I look dashing on my photo hey!
maybe a little improvement (but restrictions of a nested block remain , see for example master Lee's NestedMove program) :
(defun tst3 ( / ent col done inp ent ss i p2)
 (vl-load-com)
 (setq doc (vla-get-ActiveDocument (vlax-get-acad-object)) done nil col (acad_colordlg 0))
 (if col
     (prompt "\nEsc, enter, Rmouse to cancel, zoom with E(extend), Z(oom) or + / -\nSelect ")
     (while (not done)
(setq inp (vl-catch-all-apply 'grread (list nil 4 2)))
(if (vl-catch-all-error-p inp)
  (progn (setq done t) (prompt "\nDone."))
  (cond
    ; if point selected
    ((= (car inp) 3)
     (setq ent (nentselp (cadr inp)))
     ; if point has object under it
     (if ent
       (_uec (car ent) col)
  (if (and (setq i 0 p2 (getcorner (cadr inp) "\tOther corner : "))
    (setq ss (ssget "c" (cadr inp) p2)))
    (while (setq ent (ssname ss i)) (_uec ent col) (setq i (1+ i)))
    ); end (= (car inp) 3)
    ; user pressed E of e
    ((member inp '((2 69)(2 101))) (command "zoom" "e"))
    ; user clicked R-mouse button, pressed enter or space (done selecting)
    ((or (equal (car inp) 25)(member inp '((2 13)(2 32))))
     (setq done t))
    ; user pressed +
    ((equal inp '(2 43)) (command "zoom" "2x"))
    ; user pressed -
    ((equal inp '(2 45)) (command "zoom" ".5x"))
    ; user pressed z or Z
    ((member inp '((2 122)(2 90))) (command "'zoom" ""))
         ); end cond
       ); end if
     ); end while
   ); end progn
 ); end if col
Here's another:
(defun c:foo (/ c d e)
 ;; RJP » 2018-08-09
 (cond	((setq c (acad_truecolordlg 1))
 (setq d (vla-get-activedocument (vlax-get-acad-object)))
 (while	(setq e (car (nentsel "\nSelect entity to change color: ")))
   (entmod (append (entget e) c))
   (vla-regen d acactiveviewport)
Here's another:
 ;; RJP » 2018-08-09
cleaner and shorter... but no way I'm gonna marry you!
Ah shux...:P
