Hi i am curently working with an engineering firm, and am curently using an addon to cad2009 called DRApro.
but are wanting to uninstall the program due to bugs it has.
there is a tool in it called bounding box.
it creates a box in model space and alows you to draw in the box at a scale of your choice. then you can draw another box and draw in it and it will make it another scale you choose.
say 1 box is at 1/100 and the one next to it at 1/200
bit like viewports but in model...
also a way of selecting all hatching and deleting it....
hope it sound clear.... lol
any help would be great!
thanks,
that would be a command, its standard.
But im at home, so i can not 'help' it.
You can create viewports in model space:
Type in command line:
vports > then two, three, or four and how you want them arranged...
Hope this helps :)
thanks but sorry na not like that.
I mean its like having 2 box's and if i coppy text that is say 1/100 into the 1/200 box it will automaticaly change to 1/200.
also still stuck on the macro for a way to select all hatching and delete it.
LISP to delete all hatch:
(defun c:hatdel    (/ ss)
 (if (setq ss (ssget "X" '((0 . "HATCH"))))
     (command "_erase" ss ""))
 (princ))
