vivekgrs Posted January 20, 2009 Posted January 20, 2009 Hello everybody, iam trying to create menu in autocad.how to start.where i want to write the code for creating menu.what is mnu file. in which platform its accessable. help me regarding this Regards M.Arunachalam Quote
ReMark Posted January 20, 2009 Posted January 20, 2009 Why don't you tell us what version of AutoCAD you're using first. Some versions, such as 2004, have a .mnu file while other versions, such as 2009 have a .cui file. Quote
ReMark Posted January 20, 2009 Posted January 20, 2009 Here is some information about .mnu, .mns, .mnc, etc. files that may be beneficial to your education. http://www.markcad.com/autocad/acadmenus.htm Note that the author recommends making a copy of and then editting the .mns file. Quote
ASMI Posted January 20, 2009 Posted January 20, 2009 For me, and now *.mnu files are the best way to build a menu, and I think pros would agree with me. Far from complete but sufficient information http://www.afralisp.net/ in AutoLISP and Menu's section. You can load source menu file with _MENULOAD command in any version and *.cui file will appears automatically. Quote
ReMark Posted January 20, 2009 Posted January 20, 2009 ASMI: ML0940 posted this back in July 2008: "You can load an .mns/.mnu file anytime which gets converted to a new cui file." Is that how it works? What happens when you still want to do some additional tweaking? Does the user have to reload these files? Does AutoCAD overwrite the .cui file it created? Learn something new every day. What a place! Quote
BIGAL Posted January 21, 2009 Posted January 21, 2009 Menuload has an option to "unload" so you just unload then load your new version Quote
ASMI Posted January 21, 2009 Posted January 21, 2009 Is that how it works? What happens when you still want to do some additional tweaking? Does the user have to reload these files? Does AutoCAD overwrite the .cui file it created? You download the *.mnu, but unload already *.cui. When downloading *.mnu., *.cui be generated in accordance with the latest version of *. mnu. Quote
BIGAL Posted January 22, 2009 Posted January 22, 2009 There may be some way of reloading a mnu midstream but I always use menuload unload and load it works every time and changes the cui. Quote
