Ellen Finkelstein's Blog Posted September 27, 2017 Posted September 27, 2017 This is a guest post by Andreea Georgiana. She is a CAD enthusiast who likes using the power of Computer Aided Design to create cool useful designs, from conception to 3D printing. She has a 21-day AutoCAD course at tutorial45.com. She says, “Being able to use Computer Aided Design software to bring your ideas to life is one of the things I totally disagree only engineers should be able to do. With the numerous advantages of being able to move past the level of a 3D model to actually having the model 3D printed, anyone should consider learning at least the basics of modifying a CAD model. “As a CAD hobbyist, wife and mother, I have found many cases where a customized solution designed myself has solved a problem in the exact manner I wanted, thanks to the power of CAD and 3D printing. You can find some free tutorials here.” * * * * * Before I start, here are 2D and 3D images of the model you’ll draw in this tutorial, Use the images above to help you in completing the 3D model. Phase 1: Draw the pipe (circles) and legs (lines) Make sure the Quadrant and Midpoint in Objects SNAP settings are on. The upper parts of the legs are snapped to the left and right quadrants of the model. Later, you’ll use the Midpoint OSNAP. Then follow these steps, following the image to the right and below: Draw 2 concentric circles with R20 and R14. Draw a vertical line downward from the left quadrant of the outer circle 24 units long Draw a horizontal line of 8 units toward the left using the lower end of the vertical line you just drew as the starting point. Draw a vertical line of 6 units downward from the ending point of the previous line Draw a horizontal line of 12.4 units rightward from the ending point of the previous line Draw a vertical line of 1.6 units upward Draw a line of 1.6 units to the right Now follow these steps to trim and mirror the model: Use the TRIM command to remove the unnecessary part of the circle. Use the 2 lines that meet the circle as the cutting edges and the part of the circle between them as the object to trim. Now mirror this left side using the center of the circle to create the similar shape on the right side of the circle. Trim it to complete this step using the TRIM command. You should end up with an image similar to the one below Phase 2: Break the circles at the top Follow these steps: Use the Upper quadrant of the inner circle to draw a vertical line that crosses the outer circle. The length of the line does not matter. Use the OFFSET command with the OFFSET dimension set to 1 units to draw 2 lines on each side of the original line. Now delete the central line. Use the EXTEND command to extend the remaining lines to the inner circle. You might need to zoom in to notice that they don’t actually intersect with the circle. Use the TRIM command to trim the two circles as shown in the image below. Use the lines as the cutting edges. Phase 3: Add the top Follow these steps: Use the OFFSET command to offset the left line to the left and the right line to the right with an offset distance of 6 units. Trim the new outer lines using the outer circle as the cutting edge., Then trim the top part of the outer circle using the outer lines as the cutting edge. You want the outer lines to be 7.2 units long, as shown on the image below and then and you need to close the head using a horizontal line. One way to do this is to start the LINE command, type from on the command line and set the offset to 7.2, moving your cursor upward. The draw the LINE horizontally to the left until it intersects the outer vertical line on the left. Then trim the parts of the line that extend past the new horizontal line and trim the part of the horizontal line between the 2 inner vertical lines. Phase 4: Add the bracing (triangle) Design the little triangle on the side of the model by drawing a vertical line of 24 units, a horizontal line of 8 units, and then closing the triangle. For now, put it out to the side, separated from the main model. You can draw on top of the existing lines to start, close the triangle, and then select each of the 3 lines and move them to the right. Phase 5: Prepare for 3D conversion Use the REGION command and select everything on the drawing area to form 2 regions. At this point, if you aren’t using a 3D workspace, you should switch to one. Click the little arrow to the right of the Workspace Switching icon on the lower-right corner of the AutoCAD window and choose 3D Modeling. Phase 6: Change the view and extrude to 3D Navigate in 3D using Free Orbit. Click on Free Orbit in the navigational bar at the right, click on your mouse, hold, and move until you get a 3D view something like the one you see here. You can drag on the “orb” and its circular handles to get the right view. A keyboard shortcut might work for you: Hold down the Shift key and click and drag with your mouse’s middle (scroll) button. Use the EXTRUDE command to extrude the model by 28 units and the triangle by 6 units. On the Visualize tab, in the Visual Styles panel, click the Visual Styles drop-down and choose Shades of Gray. Phase 7: Assemble the model Follow these steps: Using the View cube at the upper right of the AutoCAD window, switch to the Top view (or go to the Visualize tab, Views panel, and click Top.) Use a regular 2D mirror command to mirror right triangle so that you have one on each side of the 3D model. Now use 3D orbit again to get a view like you see here. Use the MOVE command to move the triangle from the midpoint of its upper edge to the midpoint of the 3D line on the circle quadrant. as shown in the image here. Turn the view again so you can see the left side of the 3D model and move the left triangle in the same way. Start the UNION command, select the 3 objects, and press Enter. You have just merged the 3 object to form one. Phase 8: Add mounting holes to the base One nice thing with AutoCAD when you model in 3D is that you can still use the power OSNAP and draw 2D lines that will help you design in 3D. Follow these steps: View the model so you can create the diagonal lines shown on the image at the right. Use the Endpoint OSNAP for the start and end points. You’ll have to change the view several times as you draw the lines. Create circles using the midpoint of each of the lines you just created as the center and a radius of 2. Extrude the circles downward so the height goes completely through the model. You can select and extrude them all at once. Subtract the 4 cylinders from the model. Start the SUBTRACT command, select the model and press Enter, then select all of the cylinders and press Enter. Delete the diagonal lines. Phase 9: Fillet the sharp corners The FILLET command will help you round some of the sharp edges. Follow these steps: Select the edges with the red mark. To make it easier to select just the edge, on the Home tab, in the Selection panel, choose Edge from the Filter drop down. (You might see No Filter, Vertex or Face before you make this choice.) Use the FILLET command to round their shape with a dimension of R = 0.8 units. To FILLET, start the command, select the appropriate edge, enter 0.8, and press ENTER 2 times. Repeat the process with the opposite edge. Phase 10: Add holes in the top This is the final phase. Follow these steps: Draw the line shown on the image below using the midpoints of the two edges. Create a circle of radius 2 units using the center of the drawn line. Delete the line you just drew and create 2 lines using the quadrant of the circle and two edges you previously used. You might have to rotate the model to find the object snaps. Now, use the center of those lines to create 2 circles of radius 2. Delete the lines and extrude the 3 circles using the EXTRUDE command and make sure they go all the way through the model. Subtract those cylinders from the 3D model using the SUBTRACT command. Congratulations! You should end up with the following model. You might need to FILLET few more edges to have your model look identical to the model on the exercise. I hope this has been helpful to you! Andreea has a 21-lesson course here that you might find valuable. The post Tutorial: Create a 3D model appeared first on AutoCAD Tips Blog. View the full article Quote
