Is there a way to globally explode all the arrays (rectangular) in my design. Some of the arrays are buried in nested blocks. I didn't know if anyone has a lsp routine that could do this. All the hidden blocks that the array command makes is not working well with our conversion programs.
I have moved your thread to the AutoLISP, Visual LISP & DCL Forum.
https://www.cadtutor.net/forum/topic/56586-explode-the-new-array-rectangular-objects/
;; Explode all 'New Type' Arrays  -  Lee Mac(defun c:exarrays ( / doc enx )   (vlax-for blk (vla-get-blocks (setq doc (vla-get-activedocument (vlax-get-acad-object))))       (if (= :vlax-false (vla-get-isxref blk))           (vlax-for obj blk               (if                   (and                       (= "AcDbBlockReference" (vla-get-objectname obj))                       (setq enx (entget (vlax-vla-object->ename obj)))                       (setq enx (cdr (assoc 330 (member '(102 . "{ACAD_REACTORS") enx))))                       (= "ACDBASSOCDEPENDENCY" (cdr (assoc 0 (entget enx))))                   )                   (explode obj)               )           )       )   )   (vla-regen doc acallviewports)   (princ))(defun explode ( obj / lst )   (if       (and           (= "AcDbBlockReference" (vla-get-objectname obj))           (wcmatch (vla-get-effectivename obj) "`*U*")           (vlax-write-enabled-p obj)       )       (if           (not               (vl-catch-all-error-p                   (setq lst                       (vl-catch-all-apply 'vlax-invoke (list obj 'explode))                   )               )           )           (progn               (vla-delete obj)               (foreach obj lst (explode obj))           )       )   ))(vl-load-com) (princ)
