bijoymano Posted August 28, 2018 Posted August 28, 2018 hi all, i have drawings contain attribute block named "Sec-Mark-Up1" and mtexts and dimensions with background mask, I need to do "burst" block first and then all mtext and dimesions mask should be remove. please any one can help me to make a lisp for that. thanks and regards Bijoy Quote
tombu Posted August 28, 2018 Posted August 28, 2018 Exploding or bursting a block containing dimensions can have undesired results. Sounds like you need to modify the block's entities. Simple solution would be to modify the block and update it in each of those drawings. Quote
dlanorh Posted August 28, 2018 Posted August 28, 2018 5 hours ago, bijoymano said: hi all, i have drawings contain attribute block named "Sec-Mark-Up1" and mtexts and dimensions with background mask, I need to do "burst" block first and then all mtext and dimesions mask should be remove. please any one can help me to make a lisp for that. thanks and regards Bijoy Please post an AutoCad2010 drawing of the block and i'll take a look. Quote
