Get color funcion - clever than mine
Hi there, I've wrote a function to get and change color but I've the problem among versions of autocad. I use an English version of it but my brother has an Italian version...
(defun colore_da_lista ( value /)
   (COND ( (= (substr Value 1 6) "Colore")
         (setq colore_cordolo (substr Value 8)))
	 ( (= (substr Value 1 6) "Color ")
         (setq colore_cordolo (substr Value 7)))
     ( (OR(= Value "Rosso") (= Value "Red"))
         (setq colore_cordolo "1"))
         ( (OR(= value "Giallo") (= value "Yellow"))
         (setq colore_cordolo "2"))
         ( (OR(= value "Verde") (= value "Green"))
         (setq colore_cordolo "3"))
         ( (OR(= value "Ciano") (= value "Cyan"))
         (setq colore_cordolo "4"))
         ( (OR(= value "Blu") (= value "Blue"))
         (setq colore_cordolo "5"))
         ( (OR(= value "Magenta") (= value "Magenta"))
         (setq colore_cordolo "6"))
         ( (OR(= value "Bianco") (= value "White"))
         (setq colore_cordolo "7"))
         ( (OR(= value "DaLayer") (= value "ByLayer"))
         (setq colore_cordolo "152"))
         (t (princ colore_cordolo))
There is a better way t accomplish that? I'm sure that who develops program didn't do that for every language :)
The value comes from a FORM in OPENDCL.
Thanks for your help!
Dennis
I think this code does not work as intended.
Maybe you should look at assoc lists?
Hello! Thanks, I think you're right!
I didn't know that 256 is the number for "ByLayer" !! Thank you very much! I'll fix my code :)
(dcl-Control-GetItemData cordoli/cordoli/colore_cordolo) with that I get (256 0 1 2 3 4 5 6 7) !
Hi,
A hint for you to shorten the codes a bit if you would like to. :)
(or (vl-some '(lambda (c) (if (or (= value (car c)) (= value (cadr c))) (setq r (caddr c))))
             '(("Rosso" "Red" "1")
               ("Giallo" "Yellow" "2")))
    (setq r 256)
So the variable 'r' should be assigned with the desired return value.
@MastroLube
What I meant with my comment:
(colore_da_lista "Color White")    => "White"
(colore_da_lista "Color Red")      => "Red"
(colore_da_lista "Colore Blu")     => "Blu"
(colore_da_lista "Colore DaLayer") => "DaLayer"
So most of your cond structure never gets executed.
EDIT: I realise now that I have probably made a wrong assumption regarding the input.
Edited by Roy_043
One more thing is that, why do you have the return value of colour in a string type?
I forgot to change it to integer in my previous reply to you so please be a ware of that.
