some lisp to assign materials to different 3D elements automatically and randomly.
I dont do much with 3d but way to little information provided.
Object types
List of materials 5, 7, 25 ?
49 minutes ago, pizarro said:
Elements 3D are solids.
what is your ultimate goal?
1.- Differentiate by colors the different solids.
2.- When exporting them to Autodesk Inventor they keep the color of the material assigned.
Thank you very much for you attention.
Another option would be to assign materials for each layer
What happens is that when exporting them, Autodesk inventor does not recognize the colors but the materials.
We need a list of all possible materials.
Option Explicit
Public Sub test()
    Dim mat As AcadMaterial
    Dim matName As String
    For Each mat In ThisDrawing.Materials
        ''MsgBox mat.Name
        If UCase(mat.Name) = "SITEWORK.PLANTING.GRASS.SHORT" Then
            matName = mat.Name
            Exit For
        End If
    Next
    If Len(matName) > 0 Then
        Dim ent As AcadEntity
        For Each ent In ThisDrawing.ModelSpace
            If TypeOf ent Is AcadSolid Then
                ent.Material = matName
            End If
        Next
    End If
End Sub
Sub AddMaterialToLibrary()
    ' This example finds the name of the block associated with a layout.
   Dim material As acadMaterial
   Dim count As Integer
   count = 0
   For Each material In ThisDrawing.Materials
        If (StrComp(material.Name, "Bamboo", vbTextCompare) = 0) Then
         MsgBox "The  Bamboo  material Exists"
         count = count + 1
         Exit For
        End If
   Next
    If (count < 1) Then
       ThisDrawing.Materials.Add ("Bamboo")
    End If
    MsgBox "Done"
End Sub
The suggested list is the following:
Steel
Wood
Concrete
Aluminum
Copper
Bronze
Stainless steel
Foundry
Plastic
Glass...
