Working with DCL and LISP, Draw Steel Section
Hello again, I want to make a lisp for my DCL. Attach here is the DCL code I used.
STEEL : dialog {
          label = "STEEL";
            : row {
		:boxed_column {
			label = "Dimensions";
			: edit_box { key = "X"; label = "Width"; edit_width = 6;}
			: edit_box {key = "Y"; label = "Depth"; edit_width = 6;}
		: boxed_column {
			label = "Fillet";
			: toggle { key = "FT"; label = "Fillet Corners?"; }
			: edit_box { key = "FR1"; label = "Outer Radius"; }
			: edit_box { key = "FR2"; label = "Inner Radius"; }
	   spacer; ok_cancel;
		:text {label = ""; key = "error";}
It will give me a steel section like this in the picture. I hope someone knew about this. Thanks in advance :)
Most people do it the other way and get the draw shape to work 1st. Any way print out your object on a piece of paper and hopefully follow me here.
Point 1 lower left then all the following is polar commands.
calc p2 using width angle 0
calc p3 depth  angle (/ pi 2)
calc p4 width ang =pi
calc and so on work out all the corners no fillet yet.
Line p1 -p2 obj1 (entlast)
line p2-p3 obj2 (entlast)
fillet filletrad obj1 obj2
obj1 = obj2
line p3-p4
just keep repeating the entlast on the last two objects and apply the fillet where applicable.
This is a good lisp learning shape using polar, fillet and entlast. Last step is make it a pline as you go.
; code part
(setq fname "C:\\alan\\steel.dcl")
(setq dcl_id (load_dialog  fname))
(if (not (new_dialog "STEEL" dcl_id))
(exit))
(mode_tile "X" 3)
(action_tile "X" "(setq X (atof $value))")
(mode_tile "y" 3)
(action_tile "Y" "(setq Y (atof $value))")
(mode_tile "FT" 3)
(action_tile "FT" "(setq FT $value)")
(mode_tile "FR1" 3)
(action_tile "FR1" "(setq FR1 (atof $value))")
(mode_tile "FR2" 3)
(action_tile "FR2" "(setq FR2 (atof $value))")
(start_dialog)
(done_dialog)
(unload_dialog dcl_id)
