DavidGraham Posted September 19, 2018 Posted September 19, 2018 I'm using a LISP routine to get some data from a drawing. I'm then writing the data to an Excel spreadsheet. One of the fields should contain 'delta' with delta being the Greek letter in the shape of a triangle. I found some code that will do this but it doesn't appear to work - the cell contains '\U+0647' rather than the required symbol. The example below is for '?', once I get that to work I will change it for Delta - '\U+0184'. (setq delta (MT:Conv:Unichar->Char "\\U+0647")) -- returns --> "?" (defun MT:Conv:Unichar->Char (%unichar% / *ret*) (command "_.TEXT" '(0 0) "0.3" "0" %unichar%) (setq *ret* (cdr (assoc 1 (entget (entlast))))) (entdel (entlast)) *ret* ) Quote
BIGAL Posted September 20, 2018 Posted September 20, 2018 Hmm hold in excel pick a cell hold the Alt key down and type 0174 a ® should appear. Did you google excel and extended character set ? May give some clues of how to replicate keyboard typing with a text string. If you use mtext or text and do hold Alt down then type 0178 you will get squared 2. (setq obj (vlax-ename->vla-object (car (entsel "\nPick ")))) (setq ans (vla-get-textstring obj)) Try passing ans to a cell. I just copied from Autocad a ® to clipboard then pasted in excel and ® appeared. Quote
DavidGraham Posted September 20, 2018 Author Posted September 20, 2018 Thanks, I found that typing =UNICHAR(916) into an Ecvel cell gave the Delta symbol, therefore using the following LISP code it gave a delta symbol in cell B2. (setq cel (vlax-get-property sht 'Range "B2")) (vlax-put cel 'Value "=UNICHAR(916)") Quote
