Jim Clayton Posted September 25, 2018 Posted September 25, 2018 Does anyone know of a Lisp, that can take a Dynamic Block, and give it stretching properties, whereby it acts like a spline? The stretching would be able to curve any/every direction, like a piece of wire. Would greatly appreciate any help. Tks. Quote
Jim Clayton Posted September 25, 2018 Author Posted September 25, 2018 Basically if I had a dynamic block, and curve drawn, I'm trying to stretch it parallel to the curve. Picture that. Tks. Quote
hanhphuc Posted September 27, 2018 Posted September 27, 2018 On 9/25/2018 at 9:53 PM, Jim Clayton said: Does anyone know of a Lisp, that can take a Dynamic Block, and give it stretching properties, whereby it acts like a spline? The stretching would be able to curve any/every direction, like a piece of wire. Would greatly appreciate any help. Tks. hi, no respond maybe can try other forum has dynamic block expert? Just curious still a bit vague how a wire stretched? stretching by end? like rubber band? or like different x-scale y-scale? Quote
lrm Posted September 28, 2018 Posted September 28, 2018 Are you looking to do something like sweeping a shape along a spline? Quote
marko_ribar Posted September 28, 2018 Posted September 28, 2018 (edited) 5 hours ago, lrm said: Are you looking to do something like sweeping a shape along a spline? There is this : http://www.lee-mac.com/objectalign.html But I don't think I understand OP's question too... Maybe some example DWG with before-after case or picture could reveal his idea... Edited September 28, 2018 by marko_ribar Quote
Jim Clayton Posted October 1, 2018 Author Posted October 1, 2018 Apologies for the delay. After much searching I believe what I'm actually after is something to the effect of Stretching a Dynamic Block, or setting a Dynamic Block Array Path along a Spline...similar to the attached video. This is going to be used to draw Flex Armor/Spiral Armor, which closely resembles a/c ductwork. I have a block for it already, but sometimes the path that I need to draw it along gets a little squid-like. This would save me a ton of time. Thanks for the help. Quote
ronjonp Posted October 1, 2018 Posted October 1, 2018 Quite a few tools here for creating flexible ducts. Quote
Jim Clayton Posted October 1, 2018 Author Posted October 1, 2018 Thanks. I believe I have this one already, and it's close to what I'm after but not quite. I think I might be more in the market for a "Select Centerline, Insert Block, Insert Repeatedly-along centerline" sort of thing. Anyone ever come across something like that? Tks. Quote
Jim Clayton Posted October 1, 2018 Author Posted October 1, 2018 Think I might be able to get this to work using the ARRAYPATH command. It's definitely not 100% there but it's pretty close. Thanks to everyone for taking the time. Quote
