I'm sorry for asking too much with you guys,
but i have this sample DWG file, and i want to match all the hatch based on the color of the Upper text...
the idea I had was to match the color of the text on the hatch that is nearest to it... so thats the hatch behind the text...
new block.dwg
Can you re-post drawing in Autocad 2010 format please
try this
(defun c:test ( / ss obj pt pt2 lst)
(setq ss (ssget "x" (list (cons 0 "*text")(cons 8 "8017_textUp"))))
(setvar "osmode" 16896)
(setq obj (vlax-ename->vla-object (ssname ss (setq x (- x 1)))))
(setq pt (vlax-safearray->list (vlax-variant-value(vla-get-insertionpoint obj))))
(setq col (vla-get-color obj))
(setq pt2 (polar pt 0.78 1))
(setq lst (list (list (car pt)(cadr pt))(list (car pt2)(cadr pt2))))
(command "chprop" (ssget "f" lst (list (cons 0 "hatch"))) "" "c" col "")
2 hours ago, BIGAL said:
try this
YES SIR!!! this is the one! OMG this routine is so useful!!!! thank you so much!
No worries a fairly straight forward task it can be improved like by pick text so you get the text layer rather than hard code, you can have a go at that. Be careful the pt2 is a bit of a fuzzy value so it find the hatch so in different size objects may not work 100%.
Yeah i noticed, But im still using it. i just double the wrong ones and change it... this routine still helps me a lot, thanks!
