trefan123 Posted September 27, 2018 Posted September 27, 2018 (edited) Good day all, When loading a drawing it does not accept the "command" line eg (command "insert" "isolayer" nil) it accepts the setvars as per the code below I have copied modified the lisp to suit. Once the drawing is open it will accept the commands in lisp All blocks for insert are in the path Can i do this mix and match? Thx in advance (defun c:zz (/ cd vgad vgao vgd) (vl-load-com) (setq vgao (vlax-get-acad-object)) (setq vgad (vla-get-activedocument vgao)) (setq vgd (vla-get-documents vgao)) (setq fname (getfiled "" "D:\\AA-Programs\\A-PipingISO\\Borders" "dwg" 16)) (if (= 0 (getvar "SDI")) (vla-activate (vla-open vgd fname)) ; if sdi = 0 (vla-sendcommand vgad (strcat "(command \"_open\")\n" fname "\n")); if sdi = 1 ) ; if (setvar "cmdecho" 1) (setvar "blipmode" 0) (setvar 'osmode 53) ;(command "insert" "isolayer" nil) ;(command "insert" "dimstyle" nil) ;(command "ltscale" "0.2") ;(command "textsize" "2.5") ;(command "snapstyl" "1") ;(command "grid" "off") ;(command "ORTHO" "ON") ;(command "zoom" "e") (princ) ) Edited September 28, 2018 by trefan123 Clearer Quote
dlanorh Posted September 27, 2018 Posted September 27, 2018 (edited) Try this : (vla-sendcommand vgad (strcat "_open " fname " ")); if sdi = 1 You're trying to send a new line "\n". This is not an "enter". A space or "" is the equivalent of "enter" I'm still not sure this will work. Edited September 27, 2018 by dlanorh Quote
