ramis Posted May 22, 2007 Posted May 22, 2007 hello evreybody, i have a question... and i hope that you have an answer!!! i've got a polyline... i've exploded it and now i've got both polylines and arcs... with the pedit command, i've converted my arcs into polylines... but is it possible to convert the polylines into lines? because i have to use my drawing file in an other software and it's working better with lines... when i put polylines in it, i take the beginning and the end of my polylines and join them with a line... that's why i need only lines in my drawing... i know that with autocad you can convert lines into polylines but is it the opposite possible? thanks for your help... Quote
dbroada Posted May 22, 2007 Posted May 22, 2007 they should become polylines if you explode them (again?). Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 well, first i have a long polylines, after exploding, i've got both polylines and arcs. when i use pedit, the polylines stay and the arcs become polylines... but if i explode again this polylines, some polylines become arcs again... there's no end!!!! that's why i try to find a way to convert polylines in lines... Quote
Guest Alan Cullen Posted May 22, 2007 Posted May 22, 2007 ramis....... If you post a sample of your drawing up....we will have a closer look at it...... Basically....if you explode a polyline....you will end up with a collection of lines and arcs.....unless the polyline was a series of blocks to start with....... Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 but you're right, for the polylines which are not issued from arcs, when i explode them again, i've got lines.... the problem come from the polylines issued obtained from the arcs thanks to the pedit command... Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 here are the four files with after all the steps that i have described before... Long polyline Long polyline after explode Long polyline after pedit Long polyline after explode (2) thank you for your help... Dwg files.zip Quote
Norts Posted May 22, 2007 Posted May 22, 2007 the trick is NOT to use pedit AFTER exploding. doing so will generally recreate lines and arcs back to polylines Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 yes but after exploding, i have polylines and arcs and i only want lines... so what can i do? Quote
dbroada Posted May 22, 2007 Posted May 22, 2007 I think I am missing something. I cannot actually see anything unexpected there. If you keep exploding a polyline it will eventually resolve into lines and arcs. These are the two base drawing components. Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 ok, it works for the polylines but for the arcs, how can i convert them into lines? Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 yes dave and that's my problem... i want to convert my polylines into lines only, not into arcs and lines... so i try to find a way to approach the arcs by lines.... Quote
dbroada Posted May 22, 2007 Posted May 22, 2007 an arc is as far as a curved line will go. You may be able to apply a LISP routine to it to replace the curves with a straight line(s) but you cannot convert it. Quote
Guest Alan Cullen Posted May 22, 2007 Posted May 22, 2007 Ah so.....(as the honerable confusius said).... You have your lines......but you also want your arcs to be lines.....acad is good...BUT....it is not that good...... ...You will have to draw a line between all the arc end points, or come to grips with lisp routines (as Dave has already said). I really don't think you will get much help here for that lisp routine (except, of course, from ASMI. He loves a challenge !!!!). Cheers....and best of luck..... Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 thank you eberybody for your help... this forum is fantastic... when you post a question, few minutes later you have many persons who are ready to help you!!!! i 'll try to find an other method... maybe i will to try to play with the options of the software that i use to convert my dxf files to make it accepting the presence of arcs in the file... Quote
SEANT Posted May 22, 2007 Posted May 22, 2007 As has been stated, the options to convert a polyline with curves to purely lines is limited. There is a "Decurve" sub option with the PEDIT command, but that will only convert a polylines cuve to a staight line from one vertex to the next. In lieu of a Lisp or VBA routine, the DXB printer method (with insertion and scaling) is also an option. There is a loss of accuracy, but there will be some loss of accuracy in any arc to line conversion. DXBpolyline.dwg Quote
eldon Posted May 22, 2007 Posted May 22, 2007 If you use WMFOUT , the exporting process can't handle curves and changes them all into segmented lines. Then you can WMFIN the image, and after a couple of explodes, you have all lines. You have to include a witness line in the image that is exported, because the scaling is not good and you have to scale the image when importing it. Quote
Guest Alan Cullen Posted May 22, 2007 Posted May 22, 2007 ramis.... One of the great things that exist here........we have a lot of members who are pretty damn good......take eldon for e.g. do what he suggests... it may work for you.......get back to us if you are still having problems..... Quote
ramis Posted May 22, 2007 Author Posted May 22, 2007 thank for your advices:) indeed, the method of eldon is very good and it works... that's right alan, the members of this forum are brilliant (and i am a member )!!!! it's not the first time that i need help and each time, they found a solution to my problems!!! it's really good to see many persons ready to give you help within a few minutes!!!! (despite my explanations in Fren(ch)glish... i try to do my best to write without many errors but it's difficult) Quote
dbroada Posted May 22, 2007 Posted May 22, 2007 ramis, your writen English is far better than many native English speakers. In fact I assumed you were an ex-pat Brit. I only wish my French were as good as your English. I will be spending a week there next month and will try my best but I'm not expecting my French lasting too long. Quote
