tnvsb Posted October 1, 2018 Posted October 1, 2018 I have a lisp code that can turn on one layer at once and remaining will be in off state. (defun c:NL() (if (= lay nil) (setq num 0)) (setq entlay (tblnext "layer" num)) (setq lay (cdr (assoc 2 entlay))) (command "layer" "s" lay "off" "*" "" "") (setq num nil)) But I need modification as below that The lisp should ask which layers to be on continuously on visible state and which layers to be toggles their visibility. Suppose we have cad layers as below: Archi-wall Archi-window Archi-Floor Elect-Lights Elect-Cables Elect-Equipments. The lisp should ask 2 queries for user input as follows: 1.Please give string which layers not to be toggled: 2.Please give string which layers to be toggled: If I give user input as “Arch” as string for first query then all Archi-* layers to be continuously shown and if I give “Elect” as a string for second query then all Elect-* layers to be toggled their visiblity Thanks, T.Brahmanandam Quote
Jef! Posted October 1, 2018 Posted October 1, 2018 Hi there. There are some things that I don't quite understand. Why would you want to be asked to provide a string for layers not to be toggled to start with, if it is to than ask for a string for layers to be toggled? (ie: if you want to toggle Elect*, toggling *Elect doesn't implicitly also indicate to not toggle ARCH*? It feels like asking someone where they don't want to go before asking them for their destination...). It also could behave annoyingly; Let's say you have 1 layer on, "elect-cable", and everything else is off. Toggling "Elect*" would make you end up with elect-light/elect-equip on, but would also turn off "elect-cable". Do you know the native command Laywalk? it seems it would be way more practical than the requested lisp. You start with a dialog with the current on/off state for each layer, and can toggle them independently using control+selecting them. It can also be used with keywords, ie you type Elect*, then enter, all Elect will be turned on. By then unchecking the filter checbox, all elect* will remain on (selected), and the other layers will appear in the list (unselected, so still in an off state). Using control+mouse selection you can toggle them independently. I use laywalk/layiso/layon a lot, and never felt the need to make any lisp to control on/off state. Give it a try, if it doesn'T suit your need, let me know why, i'll see what I can do. If it does suit your needs, please mark this answer accordingly. Cheers Quote
BIGAL Posted October 2, 2018 Posted October 2, 2018 You can run layer from the command line -la off ARCH* on Elect* F asdf-1* etc Quote
