Jim Clayton Posted October 2, 2018 Posted October 2, 2018 Hello again. So I'm going to attempt to try doing some AutoCAD drawings from Excel. Keep in mind that I have no idea what I'm doing here. My theory was to take some common assemblies, find a Lisp that can copy the XYZ details and paste them into Excel to be stored for later use. I get a lot of the same requests for assemblies but all of the information is on Excel spreadsheets with dimensions. If I could pre-load those dims with coordinates, then I could draw things pretty instantly. But I need a Lisp to extract the XYZ information of assemblies and load it into Excel. Also, if someone has a better method, feel free to throw it out there. Tks. Quote
BIGAL Posted October 3, 2018 Posted October 3, 2018 You need to explain a dgw or image what is a assembly ? Quote
Jim Clayton Posted October 3, 2018 Author Posted October 3, 2018 Apologies... "Work-Speak" getting carried over into everyday life under the assumption that people know what I'm talking about. Basically just mechanical assemblies on dwg files. Things I've drawn previously. I get requests for them over and over again on massive Excel spreadsheets. You might be asking "why not just use templates?" And currently I do. But I thought if I had the coordinates for each assembly type, then I could take the spreadsheet, use some VBA to cross reference the dimensions against a coordinate template, and load the coordinates in another column based on the dimensions. And in theory, do 200 drawings like lighting. At the very least I'll learn a new skill. Thanks for the help. Quote
BIGAL Posted October 3, 2018 Posted October 3, 2018 You still have not explained need a dwg are we talking 3d solids ? Quote
Jim Clayton Posted October 3, 2018 Author Posted October 3, 2018 2d...so would actually just be XY Quote
BIGAL Posted October 4, 2018 Posted October 4, 2018 So need check what it is ! For pline a co-ords tick done Arc ends Plus centre done Circle cen pt done Text insert point done Lines end points done Its called dataextraction come with Autocad Quote
Jim Clayton Posted October 4, 2018 Author Posted October 4, 2018 Hmm... well sir, I thank you for your help. Let's see if I can make heads or tails of this. Quote
