mugshot Posted October 9, 2018 Share Posted October 9, 2018 Hi guys... Little problem... The aituation is that i have this block (set to layer 0), inside that block has different layer and color as well... I want to copy/matchprop the object inside the block, is it possible? Matchprop the object will set the destination to 0 or white, i want is to copy it without going inside/edit block in place then matchprop the object... Any help will do... Thanks in advance. Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 9, 2018 Share Posted October 9, 2018 I would use NCopy to pull the source object out of the block. You can then use the Matchprop command on the destination object and delete the source. By the same token, you could insert a dummy copy of the block, explode it, and pull off as many properties as you need. Quote Link to comment Share on other sites More sharing options...
mugshot Posted October 9, 2018 Author Share Posted October 9, 2018 Thanks cyber... But ncopy is same as matchprop the block that is set to 0, then the copied object will still be 0. Edit block in place, matchprop the source to the destination, which is better... I think. What im trying to achieve is to skip 1 method instead of 2 or 3... Ta! Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted October 10, 2018 Share Posted October 10, 2018 14 hours ago, mugshot said: What im trying to achieve is to skip 1 method instead of 2 or 3... My guess is that you'll have to write some code to do that. The question is, will you save time in the long run by investing some now in the programming. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted October 10, 2018 Share Posted October 10, 2018 23 hours ago, CyberAngel said: you could insert a dummy copy of the block, explode it, and pull off as many properties as you need. This seems like the easiest and most straightforward approach, and probably the one that I would use. If you want a command to matchprop to an object inside a block, you will need a custom lisp routine. You should post your question in the lisp section and see if anyone can help. Quote Link to comment Share on other sites More sharing options...
mugshot Posted October 17, 2018 Author Share Posted October 17, 2018 Apologies for the late response... Maybe ill do ask in lisp section... Thanks guys... Quote Link to comment Share on other sites More sharing options...
