Hello All,
see drawing.
Need some help with this. I've a template with 2 curves on it. I have it stretching to the right and keeping it arcs equal with the tangent keeping central.
What I need it to be able to stretch the Long and short edge and have the same result (two radii the same and the point of contact in the middle i.e. left side 1200 right side 600 and the point of contact 900.
Is this possible with Parameters?
Regards,
Declan.
Maybe with the scale parameters if only you can lock the height of the object that is, but i don't remember you can lock it.
Tried the scale but I would need it to scale to a lenght between 2 points, not norazontal or vertical.
Thanks,
DECHAL.
I can't think of a way to accomplish this right off the bat...You can add a second grip point to your parameter and associate another stretch parameter to the left side, but the results aren't arcs will not keep their smooth transition, i.e. you'll see a "corner" where they meet. You could try something with visibility states and some preset options to certain distances...but I'm not terribly confident that would work well either.
