rkent Posted October 11, 2018 Posted October 11, 2018 I have looked at this lisp file for a while and don't understand it well enough to make the change I am after. I would like for it to toggle between CURSORSIZE 100 and CURSORTYPE 0 when in the functions defined by the reactor. And then go back to CURSORTYPE 1 when done. ;;;Tip# 3936 By Mathew Kirkland from Cadalyst.com (vl-load-com) ;;;------------------------------------------------------------------ --; ;;; List of commands to react to: ;;; Note - This string will be used in a wcmatch statement. (setq *CursorSize_Commands* "COPY,ERASE,GRIP_STRETCH,PLOT,MLEADER,MEASUREGEOM,MOVE,SCALE,STRETCH") ;;;------------------------------------------------------------------ --; ;;; Start reactor function: (defun c:CursorSizeOn () (CursorSize:StartReactor)) ;;;------------------------------------------------------------------ --; ;;; Stop reactor function: (defun c:CursorSizeOff () (vlr-remove *CursorSize_CommandReactor*) (terpri) (prompt "\n** CursorSize reactor has been stopped ** ") (princ)) ;;;------------------------------------------------------------------ --; ;;; Start reactor function: (defun CursorSize:StartReactor () ;; Command reactors (or *CursorSize_CommandReactor* (setq *CursorSize_CommandReactor* (vlr-command-reactor nil '((:vlr-commandCancelled . CursorSize:CommandEnded) (:vlr-commandEnded . CursorSize:CommandEnded) (:vlr-commandFailed . CursorSize:CommandEnded) (:vlr-commandWillStart . CursorSize:CommandWillStart))))) ;; <- Other reactors (prompt "\n \n >> CursorSize reactor loaded ") (princ)) ;;;------------------------------------------------------------------ --; ;;; CursorSize:CommandWillStart callback function: (defun CursorSize:CommandWillStart (rea cmd / cmdName) (cond ((and (/= "" *CursorSize_Commands*) (wcmatch (setq cmdName (car cmd)) *CursorSize_Commands*)) (setq *CursorSize* (getvar 'cursorsize)) (setvar 'cursorsize 100)) ;; <- Other conditions ) ) ;;;------------------------------------------------------------------ --; ;;; CursorSize:CommandEnded callback function: (defun CursorSize:CommandEnded (rea cmd / cmdName) (cond ((and (/= "" *CursorSize_Commands*) (wcmatch (setq cmdName (car cmd)) *CursorSize_Commands*)) (setvar 'cursorsize *CursorSize*) (setq *CursorSize* nil)) ;; <- Other conditions ) ) ;;;------------------------------------------------------------------ --; (c:CursorSizeOn) (princ) Thanks for any help with this request. rkent Quote
Grrr Posted October 11, 2018 Posted October 11, 2018 Try this quick slight modification: "I would like for it to toggle between CURSORSIZE 100 and CURSORTYPE 0 when in the functions defined by the reactor. And then go back to CURSORTYPE 1 when done" "https://www.cadtutor.net/forum/topic/66200-need-lisp-file-modified-to-toggle-cursor-type/" ;;;Tip# 3936 By Mathew Kirkland from Cadalyst.com (vl-load-com) ;;;------------------------------------------------------------------ --; ;;; List of commands to react to: ;;; Note - This string will be used in a wcmatch statement. (setq *CursorSize_Commands* "COPY,ERASE,GRIP_STRETCH,PLOT,MLEADER,MEASUREGEOM,MOVE,SCALE,STRETCH") ;;;------------------------------------------------------------------ --; ;;; Start reactor function: (defun c:CursorSizeOn () (setvar 'cursortype 1) (CursorSize:StartReactor) ) ;;;------------------------------------------------------------------ --; ;;; Stop reactor function: (defun c:CursorSizeOff () (vlr-remove *CursorSize_CommandReactor*) (terpri) (prompt "\n** CursorSize reactor has been stopped ** ") (princ) ) ;;;------------------------------------------------------------------ --; ;;; Start reactor function: (defun CursorSize:StartReactor () ;; Command reactors (or *CursorSize_CommandReactor* (setq *CursorSize_CommandReactor* (vlr-command-reactor nil '((:vlr-commandCancelled . CursorSize:CommandEnded) (:vlr-commandEnded . CursorSize:CommandEnded) (:vlr-commandFailed . CursorSize:CommandEnded) (:vlr-commandWillStart . CursorSize:CommandWillStart) ) ) ) ) ;; <- Other reactors (prompt "\n \n >> CursorSize reactor loaded ") (princ) ) ;;;------------------------------------------------------------------ --; ;;; CursorSize:CommandWillStart callback function: (defun CursorSize:CommandWillStart (rea cmd / cmdName) (cond ( (and (/= "" *CursorSize_Commands*) (wcmatch (setq cmdName (car cmd)) *CursorSize_Commands*) ) (setq *CursorSizeNtype* (mapcar 'getvar '(cursorsize cursortype))) (mapcar 'setvar '(cursorsize cursortype) '(100 0)) ) ;; <- Other conditions ) ) ;;;------------------------------------------------------------------ --; ;;; CursorSize:CommandEnded callback function: (defun CursorSize:CommandEnded (rea cmd / cmdName) (cond ( (and (/= "" *CursorSize_Commands*) (wcmatch (setq cmdName (car cmd)) *CursorSize_Commands*) ) (mapcar 'setvar '(cursorsize cursortype) *CursorSizeNtype*) (setq *CursorSizeNtype* nil) ) ;; <- Other conditions ) ) ;;;------------------------------------------------------------------ Quote
rkent Posted October 11, 2018 Author Posted October 11, 2018 Thank you Grrr, that is working great. Quote
Lee Mac Posted October 11, 2018 Posted October 11, 2018 (edited) I wrote the following code some time ago, but the forum was unresponsive - nevertheless, try the following: (setq cursorreactor:com "COPY,ERASE,GRIP_STRETCH,PLOT,MLEADER,MEASUREGEOM,MOVE,SCALE,STRETCH" cursorreactor:sys '((cursorsize 100) (cursortype 0)) cursorreactor:key "cursorreactor" ) (defun c:cursorreactoron ( ) (cursorreactor:enable cursorreactor:key) (princ "\nCursor reactor enabled.") (princ) ) (defun c:cursorreactoroff ( ) (cursorreactor:cb2 nil nil) (cursorreactor:disable cursorreactor:key) (princ "\nCursor reactor disabled.") (princ) ) (defun cursorreactor:enable ( key ) (cursorreactor:disable key) (vlr-set-notification (vlr-command-reactor key '( (:vlr-commandwillstart . cursorreactor:cb1) (:vlr-commandended . cursorreactor:cb2) (:vlr-commandcancelled . cursorreactor:cb2) (:vlr-commandfailed . cursorreactor:cb2) ) ) 'active-document-only ) ) (defun cursorreactor:disable ( key ) (foreach rtr (cdar (vlr-reactors :vlr-command-reactor)) (if (= key (vlr-data rtr)) (vlr-remove rtr) ) ) ) (defun cursorreactor:cb1 ( rtr arg / val ) (if (and arg (wcmatch (strcase (car arg)) cursorreactor:com)) (progn (cursorreactor:cb2 nil nil) (foreach var cursorreactor:sys (if (setq val (getvar (car var))) (progn (setq cursorreactor:val (cons (list (car var) val) cursorreactor:val)) (apply 'setvar var) ) ) ) ) ) (princ) ) (defun cursorreactor:cb2 ( rtr arg ) (if cursorreactor:val (progn (foreach var cursorreactor:val (apply 'setvar var)) (setq cursorreactor:val nil) ) ) (princ) ) (vl-load-com) (princ) Edited October 11, 2018 by Lee Mac Quote
Grrr Posted October 11, 2018 Posted October 11, 2018 Hi Lee, Just a small tip - you could reduce the code with a single callback function, by utilising the vlr-current-reaction-name function and some conditional aswell. Quote
Lee Mac Posted October 11, 2018 Posted October 11, 2018 2 hours ago, Grrr said: Just a small tip - you could reduce the code with a single callback function, by utilising the vlr-current-reaction-name function and some conditional aswell. Maybe I'm missing something, but I don't see the advantage of this approach? This would be less efficient as there would be an additional test expression required to determine the correct course of action whenever a callback function is evaluated. Quote
Lee Mac Posted October 11, 2018 Posted October 11, 2018 3 hours ago, rkent said: Works very well Lee, thank you. You're welcome @rkent - the list of system variables & values located at the top of the code may be expanded to suit your requirements. Quote
Grrr Posted October 11, 2018 Posted October 11, 2018 1 hour ago, Lee Mac said: This would be less efficient as there would be an additional test expression required to determine the correct course of action whenever a callback function is evaluated I thought about mentioning the same - but stripped that sentence off, because I'm not sure whats more inefficient: a test expression or a pointer to the other callback function. Quote
amarcon Posted October 14, 2018 Posted October 14, 2018 Lee, Thank you, grabbing your routine as I can see it can be very useful for some tasks. Never knew it could be done so efficiently. Thanks OP for querying the great minds in this forum Quote
