Hello,
I found a lisp on the web that puts blocks on a selected polyline.
I use a script for running that script.
Works ok.........but,......
And this give me the result A (see dwg),
the question is, can it be modified to get it like in B (see mark circles in dwg)?
script:
mmp
blocks
"TAG"
1
Relative
0
A
Last
MarkMidPoints.lsp
;;  MarkMidPoints.lsp [command name: MMP]
;;  Kent Cooper, December 2011
;;  To MARK the MIDPOINT(S) of selected object(s), with Points, Blocks, or Lines.
;;  Points option:  sets PDMODE and PDSIZE to make Points visible.
;;  Blocks option:  any Block in drawing or drawing in Support File path list, any
;;    scale, any rotation including Aligned-with-object and Relative-to-object options.
;;  Lines option:  perpendicular at midpoint(s); User specifies length of Lines.
;;  For Polylines, option to mark midpoints of all segments, or only overall midpoint.
(vl-load-com)
(defun C:MMP ; = Mark Mid-Points
  (/ *error* mmp-dir mmp-reset osm cmde blips clay blktemp scltemp rotdef rottemp
  laydef laytemp pathsel path pathdata pathtype pathextr ucschanged par mmp-pt)
    ; add pdm & pds if used
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg))
    ); if
    (command)
    (if ucschanged (command "_.ucs" "_prev"))
      ;; ^ don't go back unless routine reached UCS change but didn't change it back
    (command "_.undo" "_end")
    (mmp-reset)
  ); defun - *error*
  (defun mmp-dir () ; local DIRection [radians] of path at mmp-pt location
    (angle
      '(0 0 0)
      (trans
        (vlax-curve-getFirstDeriv
          path
          (vlax-curve-getParamAtPoint path (trans mmp-pt 1 0))
        ); getFirstDeriv
        0 1 T ; world to current CS, as displacement
      ); trans
    ); angle
  ); defun - mmp-dir
  (defun mmp-reset ()
    (setvar 'clayer clay)
    (setvar 'osmode osm)
    (setvar 'blipmode blips)
; pdmode/pdsize reset possibility -- not included so Points remain visible
;    (setvar 'pdmode pdm)
;    (setvar 'pdsize pds)
    (setvar 'cmdecho cmde)
  ); defun - mmp-reset
  (setq
    osm (getvar 'osmode)
    cmde (getvar 'cmdecho)
    blips (getvar 'blipmode)
; pdmode/pdsize saving possibility -- not included so Points remain visible
;    pdm (getvar 'pdmode)
;    pds (getvar 'pdsize)
  ); setq
  (setvar 'cmdecho 0)
  (setq clay (getvar 'clayer))
  (initget "Blocks Points Lines")
  (setq _mmp-type_
    (cond
      ( ; User entry
        (getkword
          (strcat
            "\nMark with Points/Blocks/Lines? <"
            (substr (cond (_mmp-type_) ("Points")) 1 1)
          ); strcat
        ); getkword
      ); User entry condition
      (_mmp-type_); existing default if present
      ("Points"); default on first use
    ); cond
  ); setq
  (cond
    ((= _mmp-type_ "Blocks")
      (while
        (cond
          ((not blktemp)); none yet [first time through (while) loop]
          ((and (= blktemp "") (= (getvar 'insname) "")))
            ; User hit Enter, but no MMP or Insert defaults
          ((and
              (/= blktemp ""); User typed something, but
              (not (tblsearch "block" blktemp)); no such Block in drawing
              (not (findfile (strcat blktemp ".dwg"))); no such drawing in Search paths
            ); and
          ); condition
        ); cond
        (setq blktemp
          (getstring
            (strcat
              "\nBlock to insert to Mark Mid-Point(s) on path(s)"
              (cond
                (_mmp-blk_ (strcat " <" _mmp-blk_ ">")); prior Block used, if any
                ((/= (getvar 'insname) "") (strcat " <" (getvar 'insname) ">")); offer Insert's default, if any
                (T ""); no default offered on first use if no MMP or Insert defaults
              ); cond
            ); strcat
          ); getstring and blktemp
        ); setq
      ); while
      (setq _mmp-blk_
        (cond
          ((/= blktemp "") blktemp); User typed something
          (_mmp-blk_); default, if any
          ((getvar 'insname)); Enter on first use with Insert default
        ); cond
      ); set
      (initget 134 "Graphic")
      (setq scltemp
        (getkword ; [returns nil on Enter]
          (strcat
            "\nScale for Blocks, or Graphic for symbol scaled to drawing <"
            (cond
              ((= _mmp-scl_ (getvar 'dimscale)) (strcat (rtos _mmp-scl_ 2 4) "= Graphic scale"))
              (_mmp-scl_ (rtos _mmp-scl_ 2 4))
              (T "1"); default on first use
            ); cond
          ); strcat
        ); getkword and scltemp
      ); setq
      (setq _mmp-scl_
        (cond
          ((= scltemp "Graphic") (getvar 'dimscale)); User chose Graphic; get drawing scale
          ((and scltemp (/= (atof scltemp) 0)) (atof scltemp)); User typed numerical string; convert to number
          (T (cond (_mmp-scl_) (T 1))); User hit Enter and there's a default, then - use it; else - 1 [first use]
        ); cond and scale
      ); set
      (initget 32 "Aligned Relative"); dashed rubber-band if picked on-screen
      (setq
        rotdef (cond (_mmp-rot_) (T "Aligned")); Aligned default on first use
        rottemp
          (getangle
            (strcat
              "\nBlock rotation, or Aligned with path or Relative angle to path [angle/A/R] <"
              (if (numberp rotdef); if default is a number,
                (angtos rotdef); then - text, current angle units
                (substr rotdef 1 1) ; else - "A" or "R"
              ); if
            ); strcat
          ); getangle and rottemp
      ); setq
      (setq _mmp-rot_
        (cond
          ((numberp rottemp) rottemp)
            ; User typed number
          (rottemp); User typed A or R
          (rotdef); otherwise, User hit Enter -- use default
        ); cond and rot variable
      ); set
      (if (= _mmp-rot_ "Relative")
          (initget 36)
            ; no negative, dashed rubber-band if picked on-screen
          (setq _mmp-rel_
            (cond
              ( ; User input
                (getangle
                  (strcat
                    "\nAngle of Blocks Relative to path direction <"
                    (if _mmp-rel_ (angtos _mmp-rel_) "0"); designate units/precision if desired
                  ); strcat
                ); getangle & reltemp
              ); User input condition
              (_mmp-rel_); existing default if present
              (0); 0 default on first use
            ); cond
          ); setq
        ); progn
      ); if
    ); Blocks condition
    ((= _mmp-type_ "Lines")
      (if _mmp-lin_
        (initget 6); then - no zero, no negative
        (initget 7); else - no zero, no negative, no Enter on first use
      ); end if
      (setq _mmp-lin_
        (cond
          ( ; User input
            (getdist ; [returns nil on Enter]
              (strcat
                "\nEnter length of marking Lines"
                (if _mmp-lin_ (strcat " <" (rtos _mmp-lin_) ">") ""); default if present
              ); end strcat
            ); end getdist and lintemp
          (_mmp-lin_); default
        ); cond
      ); end setq
    ); Lines condition
    (T (setvar 'pdmode 35) (setvar 'pdsize -3)); Points - change values as desired
  ); cond - Blocks or Lines or Points
  (setq laydef (cond (_mmp-lay_) ("Current"))); current-Layer first-use default
  (initget 128 "Current Same"); allow Enter or non-keyword input
  (while
    (and
      (setq laytemp
        (getkword ; User input other than Enter,
          (strcat
            "\nLayer for "
            _mmp-type_
            ", or Current, or Same as selected path <"
            laydef
          ); strcat
        ); getkword and laytemp
      ); setq
      (not (wcmatch laytemp "Current,Same")); and it wasn't C or S,
      (not (tblsearch "layer" laytemp)); and Layer is not in the drawing
    ); and
    (prompt "\nLayer does not exist in this drawing--")
      ;;;; [add option to Make it?]
  ); while
  (setq _mmp-lay_ (cond (laytemp) (T laydef)))
    ; User input [including C or S], then - use it; else - default
  (if (not (wcmatch _mmp-lay_ "Current,Same"))
    ; if it's a Layer name that does exist, not current nor the object's,
    (command "_.layer" "_thaw" _mmp-lay_ ""); then - ensure it's Thawed; set current later
  ); if
  (initget "All Overall")
  (setq _mmp-plseg_
    (cond
      ( ; User entry
        (getkword
          (strcat
            "\nOn Polyline, mark All segments or Overall midpoint [A/O]? <"
            (substr (cond (_mmp-plseg_) ("All")) 1 1)
          ); strcat
        ); getkword
      (_mmp-plseg_); existing default if present
      ("All"); default on first use
    ); cond
  ); setq
  (while
    (and
      (not ; T when (while) below is satisfied
        (while
          (not
            (and
                (while
                  (and
                    (not (setq pathsel (entsel "\nSelect object to Mark Mid-Point(s) on: ")))
                    (= (getvar 'errno) 7)
                  ); and
                  (prompt "\nNothing selected -- try again.")
                ); end while
              ); not
              (if pathsel
                (wcmatch ; then
                  (cdr (assoc 0 (entget (car pathsel))))
                  "LINE,ARC,CIRCLE,ELLIPSE,*POLYLINE,SPLINE" ; omit Circle if desired, check for closed Ellipse/Spline?
                ); wcmatch
                T ; else - Enter/space for (entsel) above
              ); if
            ); and
          ); not
          (prompt "\nInvalid object type.")
        ); while
      ); not
      pathsel ; something selected - lets Enter/space end routine
    ); and
    (command "_.undo" "_begin")
    (setq
      path (car pathsel)
      pathdata (entget path)
      pathtype (cdr (assoc 0 pathdata))
      pathtype
        (if (wcmatch pathtype "POLYLINE")
          (strcase (substr (cdr (assoc 100 (cdr (member (assoc 100 pathdata) pathdata)))) 5)); then
            ;; ^ = entity type from second (assoc 100) without "AcDb" prefix;  uses this because (assoc 0)
            ;; value is the same for 2D heavy & 3D Polylines; can set UCS to match former, but not latter
          pathtype ; else - leave alone
        ); if and pathtype
      pathextr (cdr (assoc 210 pathdata))
    ); setq
    (if ; set UCS to match object only under certain circumstances
      (or ; look at entity types other than 3D Polylines and 3D Splines
        (and
          (= pathtype "LINE")
          (not ; unequal Z components at ends, in current CS
            (equal
              (caddr (trans (cdr (assoc 10 pathdata)) 0 1))
              (caddr (trans (cdr (assoc 11 pathdata)) 0 1))
              1e-12
            ); equal
          ); not
        ); and - Line UCS check
        (and
          (wcmatch pathtype "ARC,CIRCLE,ELLIPSE,LWPOLYLINE,2DPOLYLINE"); omit Circle if desired
          (not (equal (trans pathextr 0 1) '(0 0 1) 1e-12)); extrusion direction not = current CS
        ); and - A/C/E/LWP/2dP UCS check
        (and
          (= pathtype "SPLINE")
          (if pathextr (not (equal (trans pathextr 0 1) '(0 0 1) 1e-12)))
            ;; ^ planar [2D] Splines have 210 value; non-planar [3D] do not
        ); and - Spline UCS check
      ); or - need to change UCS
        (if (equal pathextr '(0 0 1) 1e-12)
          (command "_.ucs" "_world")
          (command "_.ucs" "_new" "_object" path); set UCS to match object
        ); if
        (setq ucschanged T) ; marker for *error* to reset UCS if routine doesn't get to it
      ); progn
    ); if - UCS match object
    (if (/= _mmp-lay_ "Current"); set Layer only if Current not selected
      (command "_.layer" "_set" ; [this instead of (setvar 'clayer) will turn it on if it's off]
        (if (= _mmp-lay_ "Same")
          (cdr (assoc 8 pathdata)); then - get layer of object
          _mmp-lay_ ; else - use specified Layer
        ); if
      ); command - Layer
    ); if - not Current Layer
    (setvar 'osmode 0)
    (setvar 'blipmode 0)
    (setq par -0.5)
    (repeat
      (if (and (wcmatch pathtype "*POLYLINE") (= _mmp-plseg_ "All"))
        (fix (vlax-curve-getEndParam path)); then
        1 ; else - other object types
      ); if
      (setq mmp-pt
        (trans
            (vlax-curve-getPointAtParam path (setq par (1+ par))); then
            (vlax-curve-getPointAtDist ; else - midway along length
              path
                (vlax-curve-getDistAtParam path (vlax-curve-getEndParam path)); overall length
                2
            ); getPointAtDist
          ); if
          0 1
        ); trans and mmp-pt
      ); setq
      (cond
        ((= _mmp-type_ "Points") (command "_.point" mmp-pt))
          (command
            "_.insert" _mmp-blk_
            "_scale" _mmp-scl_
            mmp-pt ; insertion point
            (cond ; rotation
              ((= _mmp-rot_ "Aligned") (angtos (mmp-dir))); local direction
              ((= _mmp-rot_ "Relative") (angtos (+ (mmp-dir) _mmp-rel_))); local direction + relative angle
              ((angtos _mmp-rot_)) ; otherwise - specified constant angle
            ); cond - rotation
          ); command
        ); Blocks condition
        (T ; [Lines]
          (command
            "_.line"
            (polar
              mmp-pt
              (+ (mmp-dir) (/ pi 2))
              (/ _mmp-lin_ 2)
            ); polar
            (polar
              mmp-pt
              (- (mmp-dir) (/ pi 2))
              (/ _mmp-lin_ 2)
            ); polar
          ); command
        ); none-of-the-above [Lines] condition
      ); cond
    ); repeat
    (setq ucschanged nil); eliminate UCS reset in *error* since routine did it already
  ); while
  (mmp-reset)
); defun - MMP
(prompt "Type MMP to Mark the Mid-Points of selected objects.")
Thank you very much, already
PmxCAD
Test-MMP.dwg
Insert this instead (mmp-dir) sub function :
    (angle
      '(0 0 0)
      (trans
          path
        ); getFirstDeriv
      ); trans
    ); angle
  ); defun - mmp-dir
  (defun mmp-dir ( / a ) ; local DIRection [radians] of path at mmp-pt location
    (cond
      ( (equal 0.0
        (setq a
          (angle
            '(0 0 0)
            (trans
                path
              ); getFirstDeriv
            ); trans
          ); angle
        ); setq
        1e-6)
        a
      ( (< 0.0 a (* pi 0.5))
        a
      ( (equal (* pi 0.5) a 1e-6)
        a
      ( (< (* pi 0.5) a pi)
        (+ a pi)
      ( (equal pi a 1e-6)
        (- a pi)
      ( (< pi a (* pi 1.5))
        (- a pi)
      ( (equal (* pi 1.5) a 1e-6)
        (- a pi)
      ( (< (* pi 1.5) a (* pi 2.0))
        a
      ( (equal (* pi 2.0) a 1e-6)
        (- a pi pi)
    ); cond
  ); defun - mmp-dir
M.R.
Actually, if you have to insert all the same attribute specification : "R1.5", use this attached mod... Note that you should change only line 420 if you have new requirement...
HTH., M.R. Also your *.scr file should end with ENTER after "Last", but you already know that...
MarkMidPoints.lsp
    (angle
      '(0 0 0)
      (trans
          path
        ); getFirstDeriv
      ); trans
    ); angle
  ); defun - mmp-dir
    (cond
      ( (equal 0.0
        (setq a
          (angle
            '(0 0 0)
            (trans
                path
              ); getFirstDeriv
            ); trans
          ); angle
        ); setq
        1e-6)
        a
        a
        a
        (+ a pi)
      ( (equal pi a 1e-6)
        (- a pi)
        (- a pi)
        (- a pi)
        a
        (- a pi pi)
    ); cond
  ); defun - mmp-dir
M.R.
M.R. works superrrrrrr...... Thanks
Marko, yours is slower and gives an error like:
Unknown command "MMP".  Press F1 for help.
Unknown command "5".  Press F1 for help.
Edited by pmxcad
