Any one know of a lisp routine that will let you window the corners of a rectangle to fillet instead of picking the corners?
Have you tried the Polyline option of the FILLET command, or are you looking to fillet specific corners?
Quote
Command: FILLET
Current settings: Mode = TRIM, Radius = 2.0000
Select first object or [Undo/Polyline/Radius/Trim/Multiple]:
Edited by Lee Mac
I second Lee Mac's suggestion. You can radius the corners of an existing rectangle but writing the code to get it to click in just the right places while not impossible would be rather tedious. Instead, if you draw the rectangle(s) with the FILLET switch you handle things in one swoop.
Lee, I use the poly line fillet command I even found a lisp that will let me window multiple poly lines and fillet all of them at once. I was just looking for a way to window a corner instead of picking two lines thought it would be faster seeing as you don't have to be so precise in picking. Not a biggy just wondering if anyone had done it. Don't sweat it.
