I need to load the "ACAD Cui" with lisp but only the "File, Window & Help" pull down menus are visible.
I'm following the sample in this link..   http://www.cadtutor.net/forum/showthread.php?26379-about-load-CUI-file
and I listing every single Pull Down Menu, but is not see the pull downs.
(setq AcadPath "C:\\Users\\<<username>>\\AppData\\Roaming\\Autodesk\\MEP 2018\\enu\\Support\\")
(setq cui_database
        (list "ACAD"                 ;<<< MENUGROUP
              (strcat AcadPath "acad.CUIX")    ;<<< PATH & CUI FILENAME
              "&File"                ;<<< MENUNAME
              "&Edit"                ;<<< MENUNAME
              "&View"                ;<<< MENUNAME
              "&Insert"                ;<<< MENUNAME
              "&Format"                ;<<< MENUNAME
              "&Tools"                ;<<< MENUNAME
              "&Draw"                ;<<< MENUNAME
              "&Dimension"            ;<<< MENUNAME
              "&Modify"                ;<<< MENUNAME
              "&Parametric"            ;<<< MENUNAME
              "&Window"                ;<<< MENUNAME
              "&Help"                ;<<< MENUNAME
              ;"&Power"                    ;<<< MENUNAME
        ) ;_ end_list
         flag nil
    ) ;_ end_setq
I need to load ALL the pull down menus, please help.
thank in advance.
DC
I thought by default all pulldown menus load if MENUBAR = 1  (setvar 'menubar 1)? Maybe your CUI is borked.
Thank you RONJONP,
the CUI is the original default from Autocad, if I loaded manually by using the command CUILOAD it load all the pull down menus,
the problem is if I use LISP.
and Yes my MENUBAR = 1
- I GOT IT...
I used a different method/lisp,
(defun ACADCUILOAD  ( / old_cmdecho old_ribbonstate)
   (setq old_cmdecho(getvar "cmdecho"))
   (setvar "cmdecho" 0)
   (setvar "MENUBAR" 1)
   (if (not (menugroup "ACAD"))
      (command "cuiload" "C:\\Users\\<<USERNAME>>\\AppData\\Roaming\\Autodesk\\MEP 2018\\enu\\support\\ACAD.cuix")
   ); end IF
    (menucmd "p1=+ACAD.POP1.FILE")
    (menucmd "p2=+ACAD.POP2.EDIT")
    (menucmd "p3=+ACAD.POP3.VIEW")
    (menucmd "p4=+ACAD.POP4.INSERT")
    (menucmd "p5=+ACAD.POP5.FORMAT")
    (menucmd "p6=+ACAD.POP6.TOOLS")
    (menucmd "p7=+ACAD.POP7.DRAW")
    (menucmd "p8=+ACAD.POP6.DIMENSION")
    (menucmd "p9=+ACAD.POP6.MODIFY")
    (menucmd "p10=+ACAD.POP6.PARAMETRIC")
    (menucmd "p11=+ACAD.POP6.WINDOW")
    (menucmd "p12=+ACAD.POP6.HELP")
    (setvar "cmdecho" old_cmdecho)
